Bad Belt Tensioner?
Bad Belt Tensioner?
I recently replaced my belt. The new belt is vibrating excessively. I can hear vibration noise from the belt in the cab at idle. I can see the belt's excess flapping between the alternator and power steering pump. If I hold it down with a screw driver handle the noise stops.
Is it time to replace the belt tensioner? Anyone else experience this problem?
Thanks!
Thanks!
He just changed his alternator. His belt was fine before. That sorta tells me that he took the belt off to do his alternator and in the process of taking it off/putting it back on his tensioner took a crap.
Thanks!
Thanks!
He changed his alternator?
Yes, its on another thread of his. He was having some idling issues and learned he had a bad alt. He then changed his alt and noticed his belt was slappin around a bit at idle.
Subscribing for knowledge,not trying to high jack but every time I replace my belt, about two to three weeks later the belt stars to wear and get jagged on one side. Im thinking tensioner or idler pulley,it also whines a little but if I spray the TOP of the belt with WD...it quits whing for a while.
Good question, but the size of the pulley would have to be different significantly in my opinion to make the belt vibrate like that. If you look at the HO alts from DB-electrical, you'll notice they come with an undersized pulley to increase output at low RPM's. The real question is at what point does the tensioner engage the belt? If it's all the way out, or very close, this may be the problem. The same result could come from the belt being too long.
Interesting side note; Orielly's did not show a part number for an idler pulley on our engine even though the belt diagram clearly showed it. The Autozone across the street not only showed the part number, but they had the part in stock.
