truck camper? - Ford Truck Enthusiasts Forums
truck camper?
Old 10-20-2008, 02:46 PM
cgah04's Avatar
cgah04 cgah04 is offline
cgah04 is starting off with a positive reputation.
truck camper?
does anyone have a truck camper for the bed? im looking to get one for the beach, make it easier to stay on the beach over night..
Old 10-20-2008, 10:49 PM
wb6anp wb6anp is offline
wb6anp has a very good reputation on FTE.wb6anp has a very good reputation on FTE.wb6anp has a very good reputation on FTE.
How about one like this, it is on a ford truck chassis
Old 10-20-2008, 10:50 PM
cgah04's Avatar
haha if it could drive on the beach and i had the extra money for a 150tho dollar rolling house wouldnt be a problem
Old 10-28-2008, 04:47 PM
cgah04's Avatar
yea those are pretty nice.. the popup ones.. anyone have these?
Old 10-29-2008, 12:31 AM
98greensi's Avatar
98greensi 98greensi is offline
98greensi is starting off with a positive reputation.
Quote:
my old man had one missed it so he bought another one recently. he hauls it around on his 79 ranger (f150 with the camper speacial).the popup has all the features of a fullsize sleeping for 4, stove fridge sink, cuboards furnace etc, it's light weight and does not catch the wind at all due to being so low. he has never had a problem with the canvas or the vynil windows. it's actually pretty worm in there. in the top bunk you have approxmently 3 feet or so hight wise.
Old 11-05-2008, 12:25 AM
98greensi's Avatar
Sorry for briniging up the old post. but i hauled my dads camper for him today, and though i'd share some pics, (for cgah04) the camper is a jayco j series 8' on my 5.5screw. The truck did fine but looked funny. the front end with a leveling kit and the *** end squitting, she was bulldogging but it was only a 20 minute drive so no big deal here's the pics...
Ps the top of the box rails measure 22" and the camper only has 20 1/4" so we had it blocked up with some 2x4's the ratchet straps were only a temp thing, and was able to use the proper hold downs in the rear.
Old 11-05-2008, 09:37 AM
cgah04's Avatar
thanks for the pics.. ive been looking around for a camper still cant find a decent used one.. new is to much for me.. hopefully ill find one.. im gona throw a set of air bags on there so it should look leveled when driving..
Old 11-05-2008, 10:53 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
First of all, remember those pics are from a truck with a leveling kit installed, which raises the front end 2". The reason these trucks have a rake from the factory is so that when they are loaded, as shown with the camper, the front end it not in the air.
Most truck campers I can find that will work on a 1/2 ton truck are about 1500 lbs, which shouldn't cause you to sag much in the rear. Especially considering the overhang most have over the cab actually shifts a good amount of the weight on the front axle.
Unless you plan on towing something heavy, in addition to your truck camper, air bags shouldn't be necessary.
Old 11-05-2008, 10:58 AM
cgah04's Avatar
i have a front leveling kit so the bags would then hold me level. correct?
Old 11-05-2008, 11:09 AM
Tom's Avatar
With a front leveling kit, you would need air bags to keep it level, under most ANY load.
The downside to all of this is that with a leveling kit, you need to effectively stiffen the rear springs immensely to maintain the "level" look...and the only good way to do that is with airbags....Which means that it's gonna ride like crap...
This is why our -150s ride so much better than an SD, because it's only sprung for an appropriate amount of weight for a half ton, instead of the massive springs required to support the truck and ~4,000 lb payload of an SD. With your leveling kit, you have no room for the suspension to give under the load without causing the truck to squat in the back....
This is why I leave the suspension alone!
Old 11-06-2008, 10:32 AM
rouschfan rouschfan is offline
rouschfan is starting off with a positive reputation.
98greensi what was the weight of that Jayco ?? I am wanting to get a slide in also, so that i can pull my boat when i go camping. I have an 05 S/C with a 6'6" bed. Thank's
Old 11-07-2008, 09:44 PM
98greensi's Avatar
Quote:
sorry for the slow reply, this one weighs 1460lbs with fridge,stove heater etc it's the 8' model
Old 11-08-2008, 08:16 AM
Thank's 98greensi,,,, I was looking at one and the weight was rated at 1630 lbs,, the reason i was asking was it look's as though you are squatting pretty good, and the one on your truck is the pop up style and the one I was looking at isn't,, I regularly haul a 220 gallon water tank in mine which equal's out to 1760 lbs @ 8 lbs a gallon. Do you guy's think it would be a problem ( the camper )?? I will also be pulling a 16' bass boat, is this to much for an F150 ? I am debating as whether or not to install airbag's on the rear. Oh,, My truck is an 05 F150 extended cab ( not super cab as i originally stated ) FX4 with a leveling kit and the 5.4 engine. Thank's
Old 11-08-2008, 08:23 AM
Tom's Avatar
rouschfan, Supercab IS the extended cab, not to be confused with the super crew, which is a crew cab.....
Remember when you look at the pictures 98greensi posted, that he had an 8' bed model, with a 5.5' bed carrying it. This meant that there was a LOT of weight behind the rear axle, which effectively transfers weight OFF the front, and puts it on the rear, which explains why he was sagging so much.
However, one of the problems he had is somethig you're going to have to deal with as well. Your front levelling kit means that it's going to be very difficult to level the truck with any kind of load on it, as the front end is already 2" higher than it's supposed to be.
If you weren't towing a boat, with a leveling kit, you probably wouldn't need the air bags. But, with the setup you're talking about, I think they'd be a big help.
New to the forum k8keeper Virginia Chapter 1 05-23-2013 10:15 AM
Where to weight truck in VA Beach? tperk100 Virginia Chapter 9 08-24-2010 09:23 PM
Overdrive Or Not With Camper LUMBERMAN 1999 - 2003 7.3L Power Stroke Diesel 19 07-10-2005 09:49 AM
Smyrna Beach Jens Florida Chapter 13 11-02-2003 12:14 AM
slide-in camper Ronct 1999 to 2016 Super Duty 7 02-02-2003 10:25 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
