Question about turbo
10-19-2008, 10:05 PM
Master of Strokes
10-19-2008, 10:10 PM
the second one but I don't remember paying $72
10-19-2008, 10:11 PM
Master of Strokes
Quote:
Originally Posted by
rbaker6336
I know when I saw 72 I was like
10-19-2008, 10:43 PM
basically you need 5 o-rings,bolts should be reusable
the 4 small o-rings should be about $3 each at ford not sure about Y-pipe o-ring
10-19-2008, 10:45 PM
on
if just pulling turbo the first one is all need if dont lose or damage anything. if pulling the pedastal youll need two of the first one.
10-19-2008, 10:57 PM
Master of Strokes
10-19-2008, 11:02 PM
weekendwarriorfsw32
2 each
F4TZ-6N653-A
F4TZ-6N653-B
you don't realy have to replace the pedistal o-rings but once that close you should
10-19-2008, 11:09 PM
Master of Strokes
rbaker6336
2 each
F4TZ-6N653-A
F4TZ-6N653-B
Is one of those numbers the pedistal o-rings?
Sorry for all the questions just don't want to mess this up.
10-19-2008, 11:15 PM
both are pedistal o-rings,takes same 2 o-rings under turbo and pedistal
that's why I said 2 of each
at the dealer you should be able to buy the four small o-rings and the Y-pipe o-ring for about $20,but I don't have the number for the Y-pipe o-ring
10-19-2008, 11:20 PM
on
I had new orings for all and reused my old ones because I liked the way they looked compared to the new ones when I put my GTP38R on. Opinions vary but so far so good. I mean I had the new stuff from Garrett and still reused the old. No problems as of yet. I call them spares now.
10-19-2008, 11:27 PM
Master of Strokes
So just to confirm there a 4 O rings that are the same?
10-19-2008, 11:30 PM
no there is a large and a small under the turbo and a large and a small under the pedistal
F4TZ-6N653-A and F4TZ-6N653-B under turbo and F4TZ-6N653-A and F4TZ-6N653-B under pedistal
10-19-2008, 11:56 PM
Master of Strokes
Ok thanks for the clarification. So thats the only new parts I need to get the turbo back in right?
10-20-2008, 12:08 AM
there is one more o-ring between turbo and spider
10-20-2008, 12:41 AM
on
rbaker6336
Definitely reuse that one. A new turbo won't even come with one of those.
