Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-18-2008, 07:47 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Does BioDiesel freeze?
just a question, but @ what temp does BioDiesel actually freeze? How about WVO? As far as I remember, water is one of the few substances that expands when it becomes solid. The reason I'm asking is our processor has a low spot that doesn't drain completely. If the Glycerin were to freeze in there, would it break the pipes? The low so far has been about 27 degrees. We are going to re-plumb it anyway to get complete drainage, but was just curious. thanks
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #2 (permalink)
Old 10-18-2008, 09:14 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Biodiesel doesn't really freeze. It will get thick and gell, but as soon as the temp increases it will revert back to good fuel. Gell temps depend on what the original oil was. If your using KOH the glycerol will not freeze, it will just get very thick, like heavy grease.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 10-19-2008, 01:06 PM
Rushmore X's Avatar
2003 Ford Excursion
thanks, we are using KOH. Probably a good idea to get all the glycerol out of there anyway so it doesn't get pumped in with the good stuff.
__________________
  #4 (permalink)
Old 10-21-2008, 08:21 PM
Gun-Driver's Avatar
Gun-Driver Gun-Driver is offline
Garage is empty, add now
Gun-Driver is starting off with a positive reputation.
I dont think you will be able to move the frozen glycern from the low spot with just the pump. That happened to me last winter, I had to use a heat gun on the pipe to liquify the glycern so the pump could move it.
  #5 (permalink)
Old 10-21-2008, 10:51 PM
Rushmore X's Avatar
2003 Ford Excursion
We are in the process of re-plumping so that there won't be a low spot, but will be a slight downhill grade to the drain. A pain due to all of the plumbing being black pipe that we cranked down real good. Never thought about the problem until now live and learn I guess.
__________________
  #6 (permalink)
Old 10-24-2008, 01:34 PM
Rushmore X's Avatar
2003 Ford Excursion
got er done, what a pain in the ...
__________________
  #7 (permalink)
Old 10-25-2008, 04:59 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud of
Glad ya got it fixed.
I'll take a stab at the original question. No, biodiesel itself does not 'freeze', but it will become fairly solid at a low enough temp - no expansion issues though (good memory).
Now the temp it gels at is quite variable depending on the feedstock. Pure canola oil has the lowest cloud point/gel point IIRC, it is close to 0*F. Hydrogenated oil is 'solid' at room temp and 'Partially' Hydrogenated oil depends on the kind of oil and the extent of 'partial' I guess, but expect the B100 to cloud slightly lower temp than feedstock.
I always keep a sample from each batch outside where I see it in the morning. When it starts to get real cold, I can tell before I get in truck if fuel is starting to cloud. If its gettin cloudy - I add a few% more diesel and then take a sample from filter bowl before shutdown. Monitor sample and add diesel if req'd...
We try to seperate out the lightest VO all year to use for 'winter-blend' B100. We have made batches that did not cloud until lower temp than pump diesel w/this stuff!
__________________
2000 Excursion, Limited, 4x4, Frybrid/V3 VO system, BTS trans, Gearhead tunes, Mahle pistons, 910 springs, chromo pushrods, headstuds, AC codes, T4/S366, carpet delete and other stuff. Also, 2001 F350 CC flatbed - currently w/no engine...
Quote:
Originally Posted by SpringerPop View Post
There are none so blind as they who WILL not see, nor so deaf as they that WILL not hear. Pop-Psalm 4:44
  #8 (permalink)
Old 10-26-2008, 09:04 AM
Rushmore X's Avatar
2003 Ford Excursion
Thanks for the info. Most of our sources are using canola as far as I know. Will mix different ratios when it starts to get colder.
__________________
Tags
bio, biodeasel, biodiesel, city, diesel, freeze, freezes, frozen, rapid, sd, seperate, temp, temperature, truck, winter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
