Tie rod end won't take grease
Sometimes heating them slightly will clear the solid grease blocking the way, use a small propane torch but be careful not to melt the boot. wrapping a soaking wet rag around the boot will help keep it from melting//burning and allow for more heat.
Myself if I can't get one to take grease I at least wait until the joint is shot before replacing it, unless of course it is stiff and causing problems already.
ya sometimes those boots have holes or whatever if its commin out there it is taking grease and as long as theres grease in it its fine...when you pump grease into it did you notice the boot expand if it expanded a bit before grease came out your fine...like dan said if it aint causin problems dont fix it
Laggy
06-16-2017 05:04 AM
72CC428
01-03-2017 11:22 PM
scrambledlife
1997-2006 Expedition & Navigator
21
10-07-2015 02:41 PM
