Cylinder Cont. test
Cylinder Cont. test
Well I'm trying to figure this truck out yet. Took it in today and had it scanned. No codes, buzz test was ok, but cannot do a cyl. cont test. Is there something else that needs to be done to do one? I made a HPOP gauge, tested the pres, 550 psi at idle, 1500 psi WOT no load, spikes to 2650 psi WOT under load. Bought new UVWH to put in later today, we'll see if that helps at all.
Unfortanitly we do not have the option with our truck, we have a contibution test yes and are fine but can be difficult for intermittant problem injectors. The cummins has a contribution test but at times will not find the problem.
I'm not on the computer that much but when you do get your scanner to work and if the contribution test does not work for you another way you can possible do this which will be a big PAIN IN THE A$$ is to unbolt your valve covers, dissconnect each injector one at a time and drive the truck under load, when you get to the rpm you encounter your problem you will be down 2 injectors, when you finally come across an unplugged injector and it still only feels like you have one cylinder down, you found your faulty injector. Just remeber every time you take for a test drive you may want to throw a couple bolts in the valve cover cause you will lose alot of oil.
ahhh, I've encountered this problem on a cummins, I've actually had to do a cylinder cut out test which cuts out one cylinder at a time manually. you'll run one cylinder down and cut out another having 2 cylinders down untill you find the faulty cylinder you want to cut out.
IT does have the choice for it, it will not let you do it though. I wonder if the oil temp sensor s not working correctly, or its just not hot enough.
UNTAMND
07-24-2013 12:47 AM
