Offroad & 4x4
GOOD LIFT KITS
Old 03-22-2000, 09:42 PM
Katt's Avatar
Katt
Katt is offline
GOOD LIFT KITS
Old 03-28-2000, 07:15 PM
Riley_7.5's Avatar
Riley_7.5
Riley_7.5 is offline
GOOD LIFT KITS
i need a good lift kit on my 95 f250. only a 3-6" lift is all i want. is more springs better or shocks? and what companies make em ? thanks
Old 04-24-2000, 07:27 PM
Ford79's Avatar
Ford79
Ford79 is offline
GOOD LIFT KITS
Tuff Country sells a 4" system with shocks, rear springs and pitman arm for about $720.00 and their 6" system is about $900.00 with shocks.The systems are $585.00 and $770.00 respectively.Superlift has systems for the same price as the Tuff Country systems.The Skyjacker systems are a little more expensive. They are $960.00 for the 4" and $1010.00 for the 6".I haven't seen any of these kits installed on one of these trucks, but I have a 6" Superlift system on my 79 F-150 and it works great.Hope this can help you with your decision on what lift to use.
Old 05-01-2000, 06:38 PM
jkiser96's Avatar
jkiser96
jkiser96 is offline
GOOD LIFT KITS
I had an 87 f-250 that had the same suspension as yours & I had a 4" kit that allowed for 38" swampers. I have lifted several trucks like yours & it takes about 1 full day to do. I had a Trailmaster kit on mine & it worked real well,right now I have a 96 f-350 with a 4" Skyjacker lift. I have put Rough Country kits on & had problems with an axle pivot mount breaking after about 20,000 miles. I done everything with my 87 & never had a problem with it but it cost a little more but if you want reliable then you will have to pay a little more.
