Grille Guard? - Ford Truck Enthusiasts Forums
Grille Guard?
Old 10-15-2008, 08:29 PM
JeremyG JeremyG is offline
JeremyG is starting off with a positive reputation.
Grille Guard?
Hi, I'm new around here, I have an '85 F250 and was wondering if anyone has seen/knows where to get a grille guard made for this generation of trucks. I've found some online, but they just bolt to the bumper, not frame mounted. Does that really matter that much? What are the pros/cons between the 2?
Old 10-15-2008, 10:56 PM
uncle.stosh uncle.stosh is offline
uncle.stosh has a good reputation on FTE.uncle.stosh has a good reputation on FTE.
The bumper is mounted directly to the frame, therefore the grille guard would be too.
Old 10-16-2008, 12:04 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
Stosh is referring to a setup like this.
The same bolts that hold the bumper on will hold the guard on as well. I have seen ones that use brackets to grab the edges of the bumper, but not on trucks this old.
Old 10-16-2008, 01:22 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
Welcome Jeremy. I can get you one built but the cost may be higher than you want. There are a lot of companies out there.
Old 10-16-2008, 04:06 PM
yeah, the only one Ive found says you have to drill holes in the bumper to attach it ...
Old 10-16-2008, 11:41 PM
Pkupman82's Avatar
Pkupman82 Pkupman82 is offline
Pkupman82 has a good reputation on FTE.Pkupman82 has a good reputation on FTE.
I bought one for my 84 F150 from JCW years ago, it is a knock-down design but it does bolt directly to the frame via the factory bumper bolts. Last I checked they are around $120, obviously you couldn't use it to push trees over but it provides a nice mounting location for off road lights and it does protect the front end from most damage. I am very happy with mine, it fit nicely and looks great... the black powder coat finish has held up well.
Old 10-17-2008, 12:36 AM
I think thats probably the same one I found, and the only one I have found that says it would fit the 80-86 year range, but I thought it said you had to drill new holes for it to mount, but maybe I misread it. how wide/tall is it approximately?
Old 10-17-2008, 09:30 AM
Give me a minute and I'll check one that I have. It's a nice aluminum one that I was going to put on my truck but decided not to.
I'll take a pic and some measurements for you.
On a side note: Here are some before and after pics of a factory OEM one that I got for another member of this board.
Nice job on the reconditioning Jerry!
Old 10-17-2008, 11:34 AM
Here is the aluminum that I was talking about. It measures about 20" tall and 6" wide and it's pretty typical of these style of push bars.
I was going to put it on my truck, but decided not to clutter up the front and hide the nice black 1980 grille that I put on.
Old 10-18-2008, 03:50 PM
GypsyR GypsyR is offline
GypsyR is starting off with a positive reputation.
The '80-86 brushguards I've seen bolt nicely into the existing bumper bolt holes. I have one that does. Though the particular one I have doesn't accept the factory bumper bolts which was annoying.
I came across a decent used one for my '87-91 truck and got it cheap. Took it home and soon realized that to mount it I would have to drill two holes in the top edge of my rather nice and original bumper. Not. It's laying around somewhere.
I imagine you saw one advertised for the later trucks and they mentioned drilling. It shouldn't be necessary for "80-86 truck. Be sure you get the right one. The uprights are contoured to fit snugly to the bumper. The older and newer bumpers are radically different in shape. This means you basically cannot bolt a later model guard to an early truck bumper. And vice-versa.
I guess you could swap out the entire bumper though. Hmmm....
Old 10-19-2008, 04:13 AM
While an 87-91 bumper would bolt to an 80-86 truck, you may have to drill 2 holes in the frame horns to accomodate all the mounting point(IIRC) and then trim a good chunk of metal off the front fenders where it drops down behind the current bumper as the newer bumper will want to occupy the same space.
Old 10-19-2008, 12:26 PM
Glockem45's Avatar
Glockem45 Glockem45 is offline
Glockem45 is starting off with a positive reputation.
Thumbs up
JC Whitney does sell 2 models, one with the wrap around light guards and one without. They also come in black or chrome.
I have found a cool on eBay that there is a company that makes them and they look tough, however I can't seem to find them on eBay anymore and have not seen them for some time now.
Honestly, I have always wanted one like the company down in Texas makes called Ranchhand bumpers, and get their Bull Bar bumper, but they don't make one for our vintage trucks. I even contacted them and a few other companies down in Texas about making one for our trucks, but they don't want to custom make anything and i was bummed out about that.
Old 10-19-2008, 01:57 PM
I believe its actually the same model, the light guards are detachable. You can buy just the guard, just the light guards, or the package of both.
and I just looked it up again and it says some drilling required, though thats in the basic description which is for all trucks it "can" fit on (ford, chevy, older, "newer", etc, etc) so it may or may not be required for the 80-86 era ... I might take a poke around my local junkyard and see if I can get lucky and find one, or if I strikeout I may just try for this one and see how it works ...
Old 10-19-2008, 02:06 PM
Glockem45's Avatar
Thumbs up
Yep, the JCW one is the some model you just have the option of with or without the light guards. If I find the one I have been seeing on eBay, I will post a link on here b/c it looks really good.
Old 10-19-2008, 02:27 PM
Glockem45's Avatar
Thumbs up
Here is the link to the one on eBay I have been seeing. If you scroll down on the add towards the bottom they actually have a picture of our truck with it mounted on the truck, and it looks pretty tough. Let me know what you think of this one.
eBay Motors: Ford Pickup Truck Chrome Grill Brush Guard Push Bar NR (item 370098834966 end time Oct-23-08 20:18:08 PDT)
2005 Ford Fx4 Grille Guard 2005FordFX4 2004 - 2008 F150 0 04-20-2015 11:43 AM
anyone have a Road Armor grill guard ? 99FORD EXPY. 6.7L Power Stroke Diesel 0 02-02-2014 08:08 AM
Ranch Hand Grille Guard (Pic Request) A/Ox4 1999 to 2016 Super Duty 19 01-14-2012 11:26 PM
Brush guard / Grill Guard - What fits? BCHauler 1987 - 1996 F150 & Larger F-Series Trucks 3 10-18-2008 05:13 PM
Brush Guard / Grill Guard / Desert Guard / Pro Runner Light Bar txmoores 1978 - 1996 Big Bronco 3 10-23-2003 10:51 AM
Tags
150, 1977, chevy, con, f150, f250, fit, ford, forum, front, fx2, grille, guard, pro, series, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
