Please Need Advice From All Of You
HI EVERYBODY , I HAVE A 1987 BRONCO THAT I WANNA PAINT , ANYBODY RECOMMEND ME A GOOD PAINT FOR A BEGINNER? SHERWIN WILLIAMS INDUSTRIAL? ACRYLIC URETHANE? IM REALLY LOOKING FOR A LOW COST PAINT JOB
http://i124.photobucket.com/albums/p...82006/3005.jpg
http://i124.photobucket.com/albums/p...82006/3011.jpg
http://i124.photobucket.com/albums/p...sensors009.jpg
THANKS IN ADVANCE
THANKS IN ADVANCE
PPG's DBU line is forgiving, well more than DBC is. Omni MAE is alright. Sherwin Williams 2nd demension is alright too. But thats a 8-4-1 mix. You want a easier mixing ratio than that. I forgot what MAE mixing is, but its less costly than DBC & DBU and probably less than 2nd demension also. Plasti-kote is cheap, but its pretty much tractor paint.
I would say Omni MAE system would be good enough. I painted a motorcycle tank and it turned out great, but the finished product is all about the underneath by prepping and perfecting the surface with filler and surfacer primer.
Good luck
Good luck
I would use MTK over MAE. They're both by PPG but the life span and gloss on MTK are a lot longer than MAE and the cost isn't much more. MAE w/hardener and reducer, for a gallon, is about $115. If you want something cheaper you can try PPG's CPC line. It is equipment paint but they make different grades. The AUE is a better grade and the mixing couldn't be easier. Its a short fill gallon of paint, so you just dump in the hardener, stir it and you're good to paint. The cost is about $65 per sprayable gallon.
OkieFromMuskogee
01-25-2015 07:23 PM
yuke175
New Member Introductions
06-17-2013 06:21 PM
1948 F1dude
03-26-2013 06:07 PM
blue964x4150
11-14-2009 03:47 PM
