Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero and 1961 - 1967 Econoline
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-13-2008, 09:28 PM
71cobrajet 71cobrajet is offline
71cobrajet is starting off with a positive reputation.
62-63 Ford econoline specs. needed
Could someone please tell me what the track width of a 62-63 Econoline van or pickup?? Basically,if someone could measure their Van or Pickup for me,it would be a great help..Thanks!
  #2 (permalink)
Old 10-14-2008, 07:49 PM
E100PU E100PU is offline
E100PU is starting off with a positive reputation.
71CJ,
I'm fairly sure this applies to all '61 to '67 pickup and vans...
Rear tread width (measured from center of tire to center of tire) 60.5 inches.
Front tread width 60.3 inches.
Hope this helps!
  #3 (permalink)
Old 10-14-2008, 08:21 PM
Yes, that is exactly what I needed! Thank you very much!
  #4 (permalink)
Old 10-14-2008, 08:39 PM
71CJ,
Not sure what your intentions are, but a 1995+, Explorer 8.8 rear end is about 59.3" and is an good candidate for a '60's Econoline swap. Rear discs, and priced very reasonable. There is a 28 and 31 tooth axle, but can't recall the years available. I'm new to the E's, so I'm learning as I go.
Again,
Good luck!
  #5 (permalink)
Old 10-15-2008, 12:04 AM
First of all,thanks for all the info....
Well,( I hope this doesn't upset anyone)the reason I needed to know this info was for a 62' Falcon gasser project..I wanted to put a straight axle under the front and I've read people were using early Econoline van axles for this swap..The front track width on a 62' Falcon(car) is 55 inches and while an Econoline axle does go underneath, I am probably going to use a custom built aftermarket tube axle for fear of reduced turning radius and fender clearance with the wider Econoline axle...
BTW, there are several very nice early Econoline vans in a junkyard near me in NJ..If anyone needs any parts,let me know..Thanks again!
  #6 (permalink)
Old 11-18-2008, 06:17 PM
jgh2k jgh2k is offline
jgh2k is starting off with a positive reputation.
Speedway makes a nice DIY axle kit that would fit your bill. or you can check with MAS in minnesota
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
