Tie rod and drag link replacement - Ford Truck Enthusiasts Forums
Old 10-13-2008, 07:39 PM
tbear's Avatar
tbear tbear is offline
tbear is starting off with a positive reputation.
Well, I had a thread going in Clutch and Tranny, but after some expert advice and troubleshooting, I am here.....
Previous thread for any reference needed. http://www.ford-trucks.com/forums/78...b-problem.html
Story: 1989 Ford F250 XLT Lariat 4x4 460 CID.
Notice a popping noise and restricted steering when front hubs locked. Recommended by FTE to check U joint. That was it. Also noticed front left tie rod end (at wheel) is loose, other end at drag link is loose, and drag link at Pitman arm is loose. Lots of play.
I will probably have the u joint replaced by a mechanic. I'm just not going there. Otherwise I will be in a confessional for a month.
So I'd like to take a crack at the steering system. I'm referencing a Haynes manual, Ford Pickups and Broncos, 1980-90. FYI
Looks like, according to the manual, tie rod is driver's side (left) and runs to the drag link, and drag link runs from Pitman arm to right wheel (passenger).
I suppose I need inner and outer tie rods....but what about Pitman arm connection to the drag link? Is there a replacement bushing for this or does the entire drag link need to be replaced also?
Right side is tight, just the left is loose. I'm trying to get the 4WD operable for the Winter. Not trying to rebuild the front end, as I will be parting company with the vehicle next Spring....or sooner if it's gonna cost a mint.
Thanks for any help. I've been Googling the tie rod replacement procedure....and feel I can to this.....just not finding much about the drag link/Pitman arm problem. Thanks, Ted
Pitman Arm Removal Question Road Warrior 95 1987 - 1996 F150 & Larger F-Series Trucks 5 07-05-2014 10:55 AM
What are all the sources of play in the steering? nothercrash 1973 - 1979 F-100 & Larger F-Series Trucks 41 09-16-2013 02:08 PM
Drag Link / Tie Rod Ends Powerstroked XLT 1994.5 - 1997 7.3L Power Stroke Diesel 13 08-09-2011 10:16 AM
Loose steering.. replace pitman arm with drag link? Kickinbass23 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-05-2010 03:47 PM
71 F100 4wd drag link and pitman arm dwillis529 1967 - 1972 F-100 & Larger F-Series Trucks 2 03-16-2004 06:39 AM
Tags
99, broncos, check, drag, draglink, f150, f250, f350, ford, link, replacement, rods, superduty, tie, tierod, trucks, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
