Warn Hubs
It's a one beer in hand while installing job. Took me longer to find the correct allen wrench out of my roll-away.
Here's the install with pics.
Auto to Manual Lockout Hub Conversion pictures from cars photos on webshots
Received 3,090 Likes
on
and they are shorter than the stock hubs, so if you use hubcaps on your mag wheels, you will have to change the fronts over to the 2005 front caps, otherwise the hubs will sit about 1 1/2 inch inside the cap. the 2005 caps fit the warn hubs perfectly.
here is the warn hub and the 02 cap.
and here is the warn hub with the 05 cap.
on
Yeah, we had a discussion about this a year or two ago. Some people said "big gap", me and a few others "no gap" - common thread was the steel vs. alloys. The alloys are thicker, so the hub sits further inside the cap.
I use a pair of pliers with rubber coated handles to turn the hub.
on
Hey guys I just purchased a set of warn hub lockers for my '00 f350, I installed them as all the very straight forward instructions say. However, with it all together I can slide the whole assembly in and out of the hub about 1/4 of an inch- making a gap and compromising the seal. The movement is between the inner mechanism on the lock and the snap ring. So now I'm confused as to why this may be.. any ideas??
