Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-13-2008, 08:25 AM
jarod17's Avatar
jarod17 jarod17 is offline
Nevada CL
jarod17 is gaining momentum as a positive member of FTE.
Question Turbo on stock 460
OK, first off my truck. I have a 1996 F-250 with a 460 motor. The motor is stock at the moment except for bypassing the AC conditioner and air intake (which is still in progress.) I do not plan on a lot of engine mods to the truck. I am going to put an aluminum rear driveshaft in after I put in a gear venders Grea splitter in the truck. I am thinking about a beafier tranny also.
I pull a 36' fifth wheel RV around from time to time and I haul a lot of weight from time to time. I also put the truck on the track every now and then.
Now for my question. What size turbo can I put on my truck without having to install bigger injectors? I know that I am going to have to make my own exhaust system to run the turbo as I have found no kits for my engine.
I am not good at algebra. Even Frederic's "monkey math formula" gets me scratching my head.
Also what would be the better set-up, a large single turbo, two small turbos, or one small and one large turbo? I know this question is more for opinions than anything.
Thanks for any advice.
__________________
Jeff-Nevada Chapter Leader
Tell me I can't do it or it can't be done I will go out of my way to prove myself right.
People who say it can not be done, should not interrupt those who are doing it. Tom Monson
1996 F-250 4X4 460, 3.55, e40d
1985 D-350 Eventually going to have a Turbo Cummins
1971 F-250 Eventually going to have a 7.3 turbo Powerstroke out of a '99 or newer F-250
  #2 (permalink)
Old 10-16-2008, 07:55 PM
Hickfied Hickfied is offline
Hickfied is starting off with a positive reputation.
i would suggest two small"ish" turbos. Don't have to wait for a large turbo to spool, and you have more air coming in than a single small turbo.
Do you know what size of injector you have stock?
Enough fuel + forged pistons + built tranny and rear = boost the hell out of it.
  #3 (permalink)
Old 10-17-2008, 07:48 AM
jarod17's Avatar
Nevada CL
Haven't looked into the injector size yet.
__________________
  #4 (permalink)
Old 10-17-2008, 08:49 AM
jarod17's Avatar
Nevada CL
Also, I know that two small turbos will give me the quick initial boost at the low end but will the boost continue through out the top end as well?
__________________
  #5 (permalink)
Old 10-17-2008, 02:57 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Freightrain is gaining momentum as a positive member of FTE.
Long as you get the right two, they should.
__________________
*signature delete option*
  #6 (permalink)
Old 10-18-2008, 07:03 AM
jarod17's Avatar
Nevada CL
So with my setup, what would be the right two?
__________________
  #7 (permalink)
Old 10-18-2008, 08:52 AM
TheTurboForums - Index
That is a VERY tough question to answer.
  #8 (permalink)
Old 10-18-2008, 06:05 PM
jarod17's Avatar
Nevada CL
OK, I found a post by Frederic this morning and came up with possibly a pair of T3's out of an '85 to '88 T-Bird.
Any thoughts or concerns with this set-up? I plan on using an intercooler as well.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
