Adjusting the setting for the auto headlights - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 10-12-2008, 11:58 PM
Freak4Ford's Avatar
Freak4Ford Freak4Ford is offline
Freak4Ford is starting off with a positive reputation.
I was wondering if there is an adjustment for when the headlights come on at dark. I would like to adjust mine if possible to come on a little bit sooner. 2004 navigator
Old 10-13-2008, 04:34 AM
c_hohensee c_hohensee is offline
c_hohensee is starting off with a positive reputation.
I don't know on your 2004, but on the 98 expy there is what looks like an adjustment on the sensor that controls the sensitivity.
Old 10-13-2008, 01:34 PM
Freak4Ford's Avatar
Thanks I will check mine today.
Old 10-17-2008, 06:08 PM
5.0gt 5.0gt is offline
5.0gt is starting off with a positive reputation.
Hi
where do I find the sensor for the autolamps in a 2003 Exp?
Roland
Old 10-19-2008, 08:34 AM
daveplot's Avatar
daveplot daveplot is offline
daveplot is starting off with a positive reputation.
Quote:
I believe it's the black "bubble" that houses the blinking red light up on the dash. I'm not sure it's adjustable though. You could always buy some window tint and put inside the cover, start with a high % tint and work down till you find what your looking for, so the sensor thinks it's darker than it actually is.
Old 10-20-2008, 05:21 AM
thanks
i will try that
Roland
Old 10-20-2008, 10:18 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Just put some black electrical tape over 1/2 the sensor.
Old 10-20-2008, 01:00 PM
04markIII's Avatar
04markIII 04markIII is offline
04markIII is starting off with a positive reputation.
wouldn't it just be easier to turn the lights on manually?
Old 10-20-2008, 01:23 PM
yeah, but I like the autolamp-feature which keeps the lights on after you turned the ignition off and leave the car
(and you do not have the lights on warning chime when you leave the car)
so i prefer the autolamp setting, but i would like to have the lights coming on earlier at dusk
does that sensor have any influence to EATC (auto air cond) as in other cars? (sensing sun rays , to blow more cold air before the temp raises, you know what i mean?)
Roland
Old 10-22-2008, 12:04 PM
SPRPRBGT SPRPRBGT is offline
SPRPRBGT is starting off with a positive reputation.
is there a way to have the fog lamps turn on with teh auto setting??? 2000 exp eb
Old 10-22-2008, 12:32 PM
alwaysfords41's Avatar
alwaysfords41 alwaysfords41 is offline
alwaysfords41 is gaining momentum as a positive member of FTE.
It wasn't possible on my '99, but is on my 2003 and 2004. I imagine your 2000 is like the 99 and that there was a gate in the switch that prevented you from pulling out the **** when in the auto mode. I had suggested elsewhere that maybe it would be as easy as chaging the headlight switch for the newer one without the gate but nobody looked it up as far as I know.
Old 10-22-2008, 12:49 PM
i was thinking of rewiring the foglight relay to be powered by the parking lamps being turned on but if i use the switch in manual i dont know if the switch would let me turn them off when just the parking lamps are on?
Old 10-22-2008, 01:25 PM
The "newer" switch lets you do that combination also.
Old 10-22-2008, 02:29 PM
well i tryd looking up the 2 switches on rockauto.com and this is what i found. betwen the 2000 and 05. the sitches look the same but they dont show a pic of the back of the 05 switch
2000 FORD EXPEDITION Headlight Switch
2005 FORD EXPEDITION Headlight Switch
Old 10-22-2008, 02:36 PM
Headlight aiming problem LIL LU 1973 - 1979 F-100 & Larger F-Series Trucks 8 01-28-2017 09:47 PM
LED headlamp adjustment Hayguy 2017 Super Duty 7 11-13-2016 12:04 AM
Automatic headlights Bugzilla46310 1999 to 2016 Super Duty 8 05-23-2016 11:18 AM
headlight adjustment 69issofine 1967 - 1972 F-100 & Larger F-Series Trucks 4 04-20-2015 09:58 AM
Adjusting when the lights come on. bkvanbek 1999 to 2016 Super Duty 18 12-09-2009 09:16 PM
Tags
1980, 2003, 2004, adjust, adjusting, adjustment, auto, bronco, expedition, f150, headlamps, headlights, lights, setting, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
