20 lpm Hydrogen Injection
I installed a "T" fitting above the PCV valve so I could inject hydrogen gas at all speeds (idle and cruise). When I injected the gas at idle, it showed a 29% increase in fuel efficiency using a scan gauge. This was determined by GPH decrease. I then made a test drive while injecting 20 liters per minute of pure Hydrogen into my engine. The results were disappointing. There was no real increase in Average MPG. I use the scan gauge for this but use the Today's Average MPG. I have to wait for this to reset each day. I have a 2000 6.8L V10.
Question:
Why am I getting a 29% increase at idle then nothing at cruise.
Is it possible that pre-ignition, during air intake, is the cause?
How do I stop or delay this?
Thanks,
Paul
Question:
Thanks,
Paul
The whole hydrogen thing is a scam really. Hydrogen has much lower energy density than gasoline. When at idle, there is very little power demand so the hydrogen helps a little. When driving, the power demand is greatly increased so the little bit the hydrogen adds makes little or no difference. Hope you didn't pay much for the instructions or equipment, its all a scam.
on
I have heard of that for propane, but I haven't heard diesel guys claim that about hydrogen, however I do tend to ignore stuff like this during times when fuel shoots thru the roof. Seems like too much of a coincidence to me that they would mention this stuff when fuel is high.
Your increase at idle was probably because engines are very inefficient idling. The added hydrogen probably helped to clean up some of the combustion inefficiency during idle which let the computer lean the fuel mixture out.
I suspect you might see some gains at wide open throttle with it however.
Maybe you are not injection enough hydrogen for there to be a difference during cruising speeds. If your on the highway turning 1700 RPMs, that means your engine is inhaling about 5780 LPM of air. With the amount of hydrogen you are injecting, that works out to an air/fuel ratio of 289:1. I think that is far to lean to see any kind of meaningful results
In a gasser, he won't, without forced induction. There's no way to get enough O2 in there to burn the H efficiently, and it's only going to throw off the PCM's closed-loop mix. Which is going to make things worse.
Thanks for the additional input, it is much appreciated.
I did make a run with 10 LPM of HHO and the same thing happened, no noticeable change in average mpg. When I ran HHO (at idle) at a flow of 20 LPM, there was a 3.8% less efficency compared to pure hydrogen.
I will make another run with an injection of 20 LPM of HHO (includes Oxygen). I'm worried about the oxygen though, in that, I don't want the 02 Sensors to see it and in-turn richen the mixture.
How much Hydrogen or HHO gas do I need to see a difference on my Scan Gauge?
I want to get the math for use on a smaller engine. My thoughts are that this stuff is possible. It may, however, not be feasible but I'm going to find out.
Thanks Lead Head, I love encouragement. I want to go as high as 100 LPM. I should have mentioned this earlier but didn't think it mattered really. I'm using a flow meter that is calibrated for air. My volume testing shows that it is actually a rate of 40 LPM, pure Hydrogen. So, my test run was with 40 LPM 100% Hydrogen. At this flow rate, do you think I'm encountering pre-ignition?
Lead Head,
By pre-ignition I'm talking about ignition during the intake stroke. I'm thinking that maybe the carbon deposits may act like hot coals and the platinum spark plugs may be igniting the hydrogen during the intake stroke. This would explain why I get a 29% increase in efficiency at idle (during free wheel). Hydrogen is highly flammable, it can be ignited by heat, static discharge or hot plugs. What do you think about injecting cold vapor or steam to prevent ignition during the intake stoke? And what do you think about changing the plugs from platinum to el cheap o?
now NOS on the other hand, is something that us diesel guys have an advantage over you gassers with because we DON'T have to achieve any stoichiometric ratios with our fuel, so there is NO danger of running lean when we inject nitrous... Nitrous is an OXIDIZER, unlike hydrogen, propane, diesel, or gasoline, which are all FUEL.
if you were to add NOS to a gas motor w/out adding an additional amount of fuel to burn , you then run the risk of burning dangerously lean.
adding hydrogen (FUEL) to an already rich mixture will not do anything to help burn unburnt fuel, since you are adding even more fuel. now you would just have even more unburnt fuel.
anytime you see black smoke coming from a diesel, you are seeing excess fuel that has not been completely burned. this is a situation where the gains from NOS can be seen because it will allow for all of this fuel to be burned and take advantage of the extra power instead of just releasing it to the atmosphere
