Dual master cylinder
If I put a dual master cylinder on my 53, do I need a check valve? I talked with a guy at my area car show who had a 54. He put on front disk brakes with a dual master without power booster. He said he had to put a check valve in to prevent the fluid from running back into the master cylinder. I believe he said he was using a master cylinder for a mustang. Does this make a difference from orderin a dual cylinder specifically for our old trucks?
on
If it's mounted under the flloor you do need a residual check valve. You can get by without it most of the time if it's mounted on the firewall. If you have disc/drum brakes you need a MC designed for disc/drums. If you don't you need one designed for drum/drum. What do you have on your truck?
on
If the MC you are using now is for drum/drum you may not need the inline residual valve since the MC should have 10 lb residual valves built in. If it is made for disc/drum and you are using it for drum/drum you will need one for the front but probably not for the rear. A power booster is not necessary unless you just prefer power brakes. I have used a manual under the floor MC and it worked fine. Also, non-power MCs are not the same bore as power MCs so you should not add a booster unless you have the right MC. Alternatively, if you try to use a power MC without a booster you may not have enough pedal pressure.
I have not looked yet, but I am sure the one on my truck now is the stock single bowl master. That is why I am looking to put a dual master on it. I will eventually put disc on it. Are you sayin I can use a dual master for disc/drum with my drum/drum? That would be great because all I would have to do is but the disc conversion kit at a later date. Will I need the proportioning valve with the dual master on drum/drum?
When Ford first installed them in 1967 on cars and trucks, all these vehicles came with a (Brake Differential) Proportioning Valve.
These valves, in most cases, were mounted inboard of the left front wheel on the outside of the frame rail. Some were mounted adjacent to the steering gearbox.
On 1967 Mustangs only, the valve is mounted adjacent to the rear axle.
There were different types used for drum/drum and disc/drum brakes.
Does it make a difference which side of the adjustable valve the Residual valve is installed on. Your diagram shows it on the wheel side I have mine mounted on the MC side. Also I was told the adjustable units were against the law for street use does anyone know if that is true.
The dual master, no booster, for both drums is part 5914 and is $89
The dual master, no booster, for front disc/rear drum is part 5913 and is $189
The check valve, 10lb or 2lb are $25.95 each, in red or blue, polished ss is $29.95
hoss73ford
32
08-22-2019 01:26 PM
pweng1
10-19-2014 09:51 AM
Smitty49
16
11-13-2013 12:18 PM
Pappys53
36
10-07-2013 12:03 PM
retrosixty6
06-22-2013 12:57 PM
