1992 Truck steering wheel wobble
Old 10-11-2008, 09:00 PM
manger's Avatar
manger
manger is offline
I have a major wobble in the steering wheel assembly. I removed the plastic shroud (have not removed the nut in the center of the wheel yet). Is this a common problem with these trucks? Not sure what the next step is. The tilt works fine, but there is about a 1/2" of play all around. In other words, I can take the steering wheel and move it up a 1/2" down a 1/2" left 1/2" right 1/2". I was told a taurus steering assembly will fit right on. I can go to the junkyard and get one from a Taurus if so. Any ideas as to what is worn out? Do they come off easily?
Old 10-11-2008, 10:31 PM
jk89cat's Avatar
jk89cat
jk89cat is offline
the bearings in the column are junk. you need to take the column apart and repair
SoCalAngler
05-04-2020 07:10 PM
Johnny Be Cool
04-01-2015 04:28 PM
jp1251
03-20-2014 08:15 PM
retroluxe
02-02-2007 08:39 PM
Quick Reply: 1992 Truck steering wheel wobble
