Some of you may know, some of you may have suspected, but it's now official. I'm an idiot. But on the outside chance this may help someone else, I'll share my story.
Pulled the valve covers off the wifes truck and re-torqued the rocker arm pedestal bolts to 20 ft-lbs, and the injector hold down bolts to 120 in-lbs because it made so much of a difference in my truck. Turned out most of her injector bolts were loose, so that's a good thing. Also did the quarter shim while I was in there to prevent that dreaded 1316 code from rearing it's ugly head.
Put everything back together, started it up, and she said I've got a CEL. Engine had a slight miss to it, so I plugged in the AE and guess what?
P1316.
Ohmed the 9 pin connectors and had a bad reading on number 3, so off came the passenger valve cover again. (I actually think this one's easer to pull this one since you don't have to mess with the intake, 42 pin connector and CCV)
I took pictures when I first got the VC off, so apparently I somehow did this while re-intalling the valve cover.
I somehow managed to unclip the wire from the #3 injector and it slid down out of the injector solenoid.
Moral of the story, if you pull your valve covers and still have an issue, or a new one shows up, it may not be the UVCH connector. You might have bumped something along the way.
Thanks for the heads up Chris. With all the trucks you retourqed, i definetly got to do this, mine are probably lose too. Great pics...
__________________ Mike's 03 F-250 7.3 CC SB XLT 4x4 Auto w/182,000 and counting. To much to list.... PAA#26 Wife's: 97 Expy XLT 4.6 4x4 comp. stock 137,000
Good post Chris. Sharing learning experiences is why we are here.
And you're not an idiot, you're one of the smartest poeple on this forum, just human like the rest of us.
Exactly what Robin said!!! To you my friend
__________________
Jim
01 F350 DRW, Autometer Gauges, Custom CAI with Petes Cover, 6" Miter Stacks, 38R Turbo, Casserly SS Injectors, Live tuned by DP-Tuner (F6) , and a bunch of other stuff some show, and some go. PAA #14 www.roadsidehelpnetwork.org RIP Mark.. I'll never forget you!!
thanksfor the info.how often does this need to be done?
We're still trying to figure this out. I've done it on trucks 99 - 02 ranging from 145k to 260k. All of them had at least 2 injector hold down bolts a little loose. Every truck has sounded better while driving after doing this. I plan on checking my truck again somewhere around the 45k range to see if anything has loosened up.
It's funny how you don't think your truck sounds bad before you do it, but you think it does sound better after.
Sounds like something I would have done.
So what did you end up getting wifey?
__________________
Chase
PAA Member #2
97 F350 CCLB 4x4 PSD
96 F350 CCLB 4x4 PSD - totaled 4/17/11 and sorely missed God speed Markadeck, you will be missed ThumperTalk / All Things Moto! / Back Country Rebels / SAWS / BRC
01 250 CC SWB Lariat Black with 285's on it. She seems to have all of ya'll beat hands down in the PMS department. Can't seem to wait on getting anything done. Tomorrow we're going to try and tackle some door lock actuators and the overhead display thing.
We met Tony Wildman last week (he lives fairly close to us) and she's getting rather impatient for a chip. I need to get a tranny cooler, VB & some gauges first, but she doesn't seem to understand why I haven't done that yet.
oh man Chris..i couldnt imagine having a women with PMS while having PMS lol you better get gauges and that VB soon..
__________________
Early 99 7.3 F350 auto,TN T-4 mount with a s467 for air,SRP 1.1 for oil,H-11 stud's,"NEW" alliant 315/200 hybrids, all supplied by unlimited diesel..shimmed 910's, DI push rod's, full fuel with a fuel lab 4202,TSD sump...tuned by Gearhead..i cant wait to drop her in the truck... http://inlinethumb43.webshots.com/50...200x200Q85.jpg
Thats why I had to open the thread when I saw "Idiot" and "F350-6" since hes one of the smarter guys on here.
She just gave you the go ahead, Go on and get yours done too!!
[quote=xgatorx1976;6639126][quote=F350-6;6638917]Also did the quarter shim while I was in there to prevent that dreaded 1316 code from rearing it's ugly head.
Quote:
What is this mod???
Instead of buying the updated shims or harness from International or Ford, you can grind the end off of a quarter and it is the right width and thickness to prevent the connector under the valve cover from coming undone.
It costs about 50 cents to equip your truck like this
__________________
Huck
Early 99 F250 with parts from Clay, Scott, Roland, Cory, JD, Pete, Christian, Neal, Jim. You could say "Built by Ford, Modded by the Brotherhood"...
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
