Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters and Ram Air
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-11-2008, 04:33 PM
F350 Strait F350 Strait is offline
F350 Strait is starting off with a positive reputation.
Modifying a 460 Edlebrock Air Gap
I'm running a 545 with an Edlebrock dual-plane Air Gap. I've been thinking of grinding most of the wall between the two plenums - at least to the floor of the upper plenum for a little more performance. At this time I don't want to go to a single-plane manifold. I have this engine in a '79 F350 that I pull a fifth wheel trailer and I feel that the dual-plane gives me a little more lower end torque and I'm not looking for power up high.
Can anyone tell me if this will work?
Thanks
  #2 (permalink)
Old 10-22-2008, 03:24 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
It's aluminum and if you do go too far you can patch it pretty easily. However it would probably be much easier to put in a spacer to increase the phenolic volume.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #3 (permalink)
Old 10-22-2008, 09:31 PM
Thanks ReAX
I have a spacer and found out at the machine shop that I use that I can notch & blend the parts of the spacer that separates the 4 carb openings - it's not an open plenum spacer. It should be easier than cutting on the intake.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
