Need wiring diagram for 1991 F250 Diesel
Old 10-11-2008, 03:23 PM
frank-id's Avatar
frank-id
frank-id is offline
I have a trouble shooting manual but alas, no traceable diagram. Direct me or send diagrams. Tracing wiring in truck is a difficult task... Frank
Old 10-11-2008, 09:35 PM
PLC7.3's Avatar
PLC7.3
PLC7.3 is offline
What do you need to trace for wiring.........??
Old 10-11-2008, 09:43 PM
frank-id's Avatar
frank-id
frank-id is offline
A wiring diagram is valuable for me
I'm an old electrician of 35 years. A wiring diagram can instantly identify any wire. Some diagrams also show wire routing. I have lots of testers, voltage lites, and flashers, but nothing beats a factory diagram. Some times there is a circuit that is not used on a vehicle. I some times use those wires for other purposes. I use lots of Bosch type cube relays as well as aircraft manual reset breakers. Frank
Old 10-11-2008, 10:05 PM
GenLightening's Avatar
GenLightening
GenLightening is offline
I've used them from here, Automotive Wiring Diagrams and they work pretty good.
Old 10-12-2008, 10:02 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
I have seen a lot of different wiring diagrams for the older vehicles.
All of them show where the wire comes from and goes to, but I have never seen one that showed the route it takes to get there.
Also none of them show where the components are actually located.
I am a master electrician as well.
Old 10-12-2008, 12:06 PM
GenLightening
Fortunately, for my engine swap, I'm pretty good at puzzles! Motorcycle schematics are great, usually in color and they show the entire harness in one shot, so you can trace things easily. Why do auto makers make things so hard? My dad has a diagram for his '73 Pantera that is in color, and complete from one end to the other.
Old 10-13-2008, 08:37 PM
frank-id's Avatar
frank-id
frank-id is offline
Hey Dave Please help
I have been rewiring my head lite switch. I have been trying to discover where the wires connected to the switch are going. Using a jumper, I have discovered the park lites, head lites and dash lites. There are 8 connections plus a very large maybe #10 supply wire with 12volt. Any hints and colors of same of conductors is appreciated. Frank
Old 10-13-2008, 10:16 PM
Dave Sponaugle
I actually tapped into my light circuit out under the master cylinder.
On my 86,
light brown for park lights
Solid red was low beam
Solid green was high beam
I know a lot of the colors changed on the 87 model though.
PS if you tap in under the dash, ....wait your dimmer switch is in the steering column isn't it.
Mine is on the floor, I had to go outside to get the low high beam after the floor mounted switch.
Old 10-14-2008, 08:50 PM
frank-id's Avatar
frank-id
frank-id is offline
Hey Doug
Send me an email...
frank.id.crown@gmail.com
brucewon
05-19-2023 02:59 PM
fp_5
1983 - 2012 Ranger & B-Series
10-28-2012 10:14 AM
shawbran
06-02-2011 09:23 AM
Hunt89
01-01-2010 05:22 PM
stingray
Electrical Systems/Wiring
12-17-2000 09:40 AM
Quick Reply: Need wiring diagram for 1991 F250 Diesel
