Need wiring diagram for 1991 F250 Diesel - Ford Truck Enthusiasts Forums
Old 10-11-2008, 04:23 PM
frank-id frank-id is offline
frank-id is starting off with a positive reputation.
I have a trouble shooting manual but alas, no traceable diagram. Direct me or send diagrams. Tracing wiring in truck is a difficult task... Frank
Old 10-11-2008, 10:35 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
What do you need to trace for wiring.........??
Old 10-11-2008, 10:43 PM
A wiring diagram is valuable for me
I'm an old electrician of 35 years. A wiring diagram can instantly identify any wire. Some diagrams also show wire routing. I have lots of testers, voltage lites, and flashers, but nothing beats a factory diagram. Some times there is a circuit that is not used on a vehicle. I some times use those wires for other purposes. I use lots of Bosch type cube relays as well as aircraft manual reset breakers. Frank
Old 10-11-2008, 11:05 PM
GenLightening's Avatar
GenLightening GenLightening is offline
GenLightening is starting off with a positive reputation.
I've used them from here, Automotive Wiring Diagrams and they work pretty good.
Old 10-12-2008, 11:02 AM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
I have seen a lot of different wiring diagrams for the older vehicles.
All of them show where the wire comes from and goes to, but I have never seen one that showed the route it takes to get there.
Also none of them show where the components are actually located.
I am a master electrician as well.
Old 10-12-2008, 01:06 PM
Fortunately, for my engine swap, I'm pretty good at puzzles! Motorcycle schematics are great, usually in color and they show the entire harness in one shot, so you can trace things easily. Why do auto makers make things so hard? My dad has a diagram for his '73 Pantera that is in color, and complete from one end to the other.
Old 10-13-2008, 09:37 PM
Hey Dave Please help
I have been rewiring my head lite switch. I have been trying to discover where the wires connected to the switch are going. Using a jumper, I have discovered the park lites, head lites and dash lites. There are 8 connections plus a very large maybe #10 supply wire with 12volt. Any hints and colors of same of conductors is appreciated. Frank
Old 10-13-2008, 11:16 PM
I actually tapped into my light circuit out under the master cylinder.
On my 86,
light brown for park lights
Solid red was low beam
Solid green was high beam
I know a lot of the colors changed on the 87 model though.
PS if you tap in under the dash, ....wait your dimmer switch is in the steering column isn't it.
Mine is on the floor, I had to go outside to get the low high beam after the floor mounted switch.
Old 10-14-2008, 09:50 PM
Hey Doug
Send me an email...
frank.id.crown@gmail.com
glow plug wiring diagram olyellow 6.0L Power Stroke Diesel 1 03-28-2013 09:40 PM
2007 wiring diagram fp_5 Ranger & B-Series 4 10-28-2012 11:14 AM
02' Excursion Wiring Diagram Bobsandog Excursion - King of SUVs 1 07-19-2012 05:44 PM
Wiring Diagram shawbran 1987 - 1996 F150 & Larger F-Series Trucks 12 06-02-2011 10:23 AM
rewire 1972 p350 fvassar Electrical Systems/Wiring 2 01-05-2011 09:24 PM
Tags
1991, 250, 4x4, 73, diagram, diagrams, diesel, disel, electrical, engine, f250, ford, truck, wire, wireing, wirering, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
