Coolant Strength Low After Flush & Change
Last week I changed my coolant and yesterday I checked it's strength using one of those cheap, floating *****, testers. It is reading low (-10 degrees protection as opposed to -20 before the change).
This was my first time changing coolant in a vehicle with a degas reservoir.
I drained the radiator and the two block drains. Then filled with tap water and chemical flush. Ran it for 15 minutes. Drained the radiator and block again. Filled again with tap water and let run 15 minutes. Drained radiator and block again. Then filled with 50/50 distilled water and antifreeze.
I was able to get in only about 14 quarts of mixed coolant. I think the system is supposed to hold about 20 total.
Did I do something wrong and not get all the tap water out before putting in the new coolant?
Is it possible the tester I used is inacurate?
This a 2001 F-150 with 105K miles that has had regular coolant changes per Ford schedule.
"Then filled with 50/50 distilled water and antifreeze.
I was able to get in only about 14 quarts of mixed coolant. I think the system is supposed to hold about 20 total. "
You answered you own question. If you know your cooling system holds 20 quarts total (using data from your owner's manual) then 50/50 mix of 14 quarts will get you only 7 quarts of coolant, that's only 35% coolant mix, not 50/50. You still had water in the system before you added the mix.
Stewart_H
508
09-15-2023 04:57 PM
68bluebeast
1997-2006 Expedition & Navigator
03-08-2015 08:48 PM
