Sagging Door Handles - Ford Truck Enthusiasts Forums
Old 10-10-2008, 08:47 PM
Woodsman_30350's Avatar
Woodsman_30350 Woodsman_30350 is offline
Woodsman_30350 is starting off with a positive reputation.
The door handles on my '50 F1 are sagging a bit and I would like to know if anyone has any secrets to get them level. I have cleaned and lubed the mechanism and the spring is very strong. I even replaced the rubber stop riveted to the latch plate thinking that would help. So far, Nada!!
I did notice the the angle on the at the end of the latch plate where the latch protrudes in not 90 degrees. Is this normal or should I true it up?
Old 10-10-2008, 09:05 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
I fixed the handles on one of my trucks very easily. I wish I had taken pictures as I did it. It's hard to explain but you have to take the latch mechanism out of the door. There is a box that the handle shaft goes through. If I can remember correctly you have to disassemble the box carefully so as not to break off the retaining tabs. Once you have the box apart you will see two parts that are worn, here's where I wish I had taken pictures, I have a very bad memory, but you should be able to notice the two parts inside the box that are worn. I built up the worn parts with a few tacks from a mig welder and filed the welds back into the shape the worn parts to the original shape.
Sorry about the bad description but once you have the box apart you should see what I am talking about.
Old 10-10-2008, 09:27 PM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Hey Bob!
Does this help?
The caption in the photo is wrong, top photo is drivrs side, bottom picture is the passengers side. Having a 5 Star Deluxe I have locks on both sides.
I'm not sure if you can but maybe modify this picture to show him what you meant. I am pretty sure I understand, but I've done it too. The cover is over the bolt slide. On the bottom picture you can see the tabs that hold it on. You DON'T want to break these off.
J!
Old 10-10-2008, 10:05 PM
bobj49f2's Avatar
Julie,
I tried to remember exactly what I did to fix the sagging. I am pretty sure I
had to disassemble the entire mechanism.
One of the two areas (red arrows) I think were worn and I built them up with the MIG welder. I also remember having to remove the "U" piece (blue arrow). I also removed the cover (yellow arrow) and welded something under there too.
It's very frustrating not remember what I exactly did. I am very sorry that I didn't take pictures as I did it. When I did it I was in a hurry and I know it didn't take a lot of time. The handles came out perfectly straight without any play. I am sure if someone wants to repair them they can do it, just be careful when twisting the tabs. They won't take more than one twist to straighten and one more to twist back into position.
Old 10-10-2008, 11:44 PM
Thanks for input. This one will take some thought. I know there is play in there but just cannot figure out where. Maybe when I get it assembled, I will be able to do it.
Old 10-11-2008, 02:06 AM
One of the things I found that made mine sloppy was that the square shaft that fits through the blot, and the square hole in the bolt were worn. When I took mine apart, I heated and flattened the bolt hole with a ball peen hammer some to shrink it back down. I also welded some extra metal on the shaft and filed it square to tighten that up.
Also, I had to tighten up the areas Bob is talking about. The band under his blue arrow is actually a piece of spring steel that holds the bolt slide. You have to remove it to get to the bolt.
Also, make sure the screw holding your handle in the door is tight.
I have an extra pair of these out in the garage. Let me go out and look at them tomorrow and I'll get back to you with something more specific, and some better pictures.
J!
Old 10-11-2008, 06:06 AM
Thanks Julie and Bob.
Old 10-11-2008, 07:12 AM
49willard 49willard is online now
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
A cheater way to cure the sag would be to remove the handle, put the square end in a vice, heat the square in an appropriate spot along its length to cherry red and twist the handle slightly (in the correct direction) putting the amount of twist in the square shank to compensate for the sag. If you are really good you might just get it on the first try! Note that it is easily reversible if you decide to disassemble and repair as Bob did.
Not being from the south, would this qualify as a cottie bob fix?
Old 10-11-2008, 12:23 PM
Quote:
Tee hee - probably not!
As a matter of fact I wouldn't be surprised (and I'll catch heck from Bill for saying this) if it wasn't an approved Ford Repair Procedure!
Have you ever seen the "Door Adjustment" procedure in the shop maual?
It involved putting a rubber mallet in a strateic location between the door and cab, then reefing on the door!
Ah life was so simple back them!
J!
Old 10-11-2008, 03:48 PM
Question - It appears I will have to heat the tabs to bend them up so I can get to the parts to be repaired. Is that was you all did? I tried prying them up and there is no way.
Old 10-11-2008, 05:19 PM
dennisb56's Avatar
dennisb56 dennisb56 is offline
dennisb56 is gaining momentum as a positive member of FTE.dennisb56 is gaining momentum as a positive member of FTE.
This is a interesting thread, I need to correct this on my 52 also. Do you have to remove the door glass to get these handle assemblies out? Just curious.
Thanks
Old 10-11-2008, 08:03 PM
bobj49f2's Avatar
If you heated the square shaft it might solve the sagging handle problem but you still have slop in the handle.
I don't think you will have to remove the glass. The door I did this on didn't have the glass in but if you have the widow rolled up you should be able to remove the bolts holding the door latch mechanism and remove the unit.
Old 10-11-2008, 08:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
All this is interesting. I had a good look at mine way back when, and it appeared the problem was the cam action in the handle and base on the outside of the door. They are shaped so when you move it to open the door, it cams outwards, and a spring on the shaft behind the base tries to pull it back. When they get worn, there isn't enough cam action and the spring gets weak.
With the inner mechanism out, the handle should be able to return on its own. There could be two separate problems here?
Old 10-12-2008, 07:03 AM
Bob,
I agree with you. It will only bring the handle back to level. I did ask if this fit in the cootie bob category.
Old 10-12-2008, 12:47 PM
bobj49f2's Avatar
Yes, cousin Bill,
cottie bob all the way
08 E-150 Door Latch sticks BobRobi 1968-2013 Full Size Vans 2 12-25-2016 06:57 PM
94 F-250 XL Door Sagging Just A Little justplumducky 1987 - 1996 F150 & Larger F-Series Trucks 8 12-05-2016 08:51 PM
1971 C600 Door Latch Joe Kelly 1967 - 1972 F-100 & Larger F-Series Trucks 13 09-20-2016 01:03 PM
Interior door handle - catching hillcountryflt 1967 - 1972 F-100 & Larger F-Series Trucks 3 11-30-2014 01:33 PM
Moving tailgate latch POPAJON 1973 - 1979 F-100 & Larger F-Series Trucks 6 03-01-2011 08:51 AM
Tags
1951, 1960, 48, door, doors, ford, handle, installing, interior, key, lock, locks, removing, sagging, side, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
