Sagging Door Handles - Page 2 - Ford Truck Enthusiasts Forums
Old 10-14-2008, 05:17 PM
Woodsman_30350's Avatar
Woodsman_30350 Woodsman_30350 is offline
Woodsman_30350 is starting off with a positive reputation.
Julie,
FYI Ford issued a TSB to the original manual encouraging you to purchase a variety of rubber mallets so you can "fine tune" your adjustments.
Old 10-14-2008, 05:35 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
The doors were so far off in the cab I used for my F-2 I had to use a hydraulic jack to push the upper right and lower left corner to make the door square. The cab was from a firetruck with 3000 miles and was in perfect condition otherwise.
Old 10-14-2008, 05:59 PM
Well! I guess we should add the hydraulic ram to the assortment of rubber mallets.
Old 10-14-2008, 06:04 PM
Hey Bob. I understand why you would not take pictures of the fix you did but it is never too late. Why don't you take you door apart, remove the cover and take a picture of the modification you made. I can assure you I would be eternally grateful!
Old 10-14-2008, 07:10 PM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Well, I've been abscent from this post for awhile. Just to catch up: You don't have to remove the glass from the window track to get the door lock mechanism out. You will probably have to jimmy it around a little though and maybe role the window down a little or up a little to get it past it.
But be careful, it's one of those funny parts that if you don't touch it it will fall out into the bottom of the door by itself, but you'll be swearing to figure out how it did it when you can't get it out by itself or back in. Actually they aren't to difficult.
I checked my new handles and there is no spring or any type of mechanism in the handle itself. The handle with the shaft will turn 360 deg in the mounting base and stay put where ever you leave it
I decided to donate my extra lock to the cause and disect it (because I don't remember what's in there either). And this is the bottom line: If your handles are sagging it's because either 1) your square hole in the handle hole is rounding out; 2) the square shaft on the handle is rounding out; the spring holding ht ebolt taught has broken or is weak; and/or, 4) the metal tab on the bolt actuator is bent or worn!!!
"Bolt actuator? What up with that Julie?" Ok here's the pictures:
Here's the lock with the cover on. You won't need to heat the tabs on the back - there are only two. Be sure to clamp that coiled spring...that sucker is super tense.
Carefully get a screw driver and hammer and get under the tabs just enough to get a pair of "dikes" under each one. You may have to lightly pry up on the cover then pull it back out from the bolt face - you'll understand when you see it.
This is what you see when you pull off the cover. The top piece is the door lock cam. It is pushed up by the keyed lock below or by flipping the inside door handle counterclockwise. Note that the square hole in it is somewhat over sized.
When you lift off the locking cam this is what you see. This piece with the square hole is what actuates the bolt. You can see that the bolt is held rigid by the spring. When the handle is turned, the tab on the top of this "bolt actuator" pushes the bolt back against the spring pressure.
So, the only place you can have play in that linkage is on the handle shaft; in the handle shaft hole; there is not enough spring pressure to hold the bolt in place; OR that tab on the top of the actuator is worn (quite a bit) or bent out of place.
This lock set functions perfectly so the positions of the parts you see here is what you want. I would imagine that Bobs fix was to build up the tab.
Be very gentle with the tabs when you take this apart AND when you put it back together. I had no problems with them.
J!
Old 10-14-2008, 07:45 PM
Julie, I think some of the metal surfaces are worn since the spring appears to be very strong. I will not really know what I need to do until I get it apart.
I will let you know if I need pictures and thanks for the offer.
Old 10-14-2008, 08:13 PM
Hi Wood!
I edited them in while you were writing!
J!
Old 10-14-2008, 11:12 PM
It is Christmas in October!!!!! Thanks a million and I will let you know how it turns out.
W
Old 11-06-2008, 06:09 PM
Just on update. I just reassembled my '50 F-1 doors and wanted to report on correcting the sag in my outside door handles. See Julie's post #20 in this thread that shows pictures of what the internal components should look like on proper functioning handles.
I took my latch mechanisms apart and, as Bob mentioned, noticed quite a bit of wear on the bearing surfaces of the components. I MIG welded the worn surfaces so they mirrored Julies photo and reassembled the mechanisms. You would not believe the difference. The handles and mechanisms now function like a brand new vehicle.
Thanks Julie and Bob. You made me one happy camper. I will post photos of the finished product in my gallery soon.
Old 11-06-2008, 06:33 PM
bobj49f2's Avatar
Good to hear you were successful. It's a fairly easy fix if you have MIG welder.
Old 11-08-2008, 01:21 PM
dennisb56's Avatar
dennisb56 dennisb56 is offline
dennisb56 is gaining momentum as a positive member of FTE.dennisb56 is gaining momentum as a positive member of FTE.
This was a great thread. The pics from Julie really helped me make some sense of whats going on with my handles. I need to save this thread for spring when the serious work on my truck begins!
Old 11-08-2008, 08:45 PM
48' fordster's Avatar
48' fordster 48' fordster is offline
48' fordster is starting off with a positive reputation.
Would Viagra or Cialis work for your "sagging" problem? just my two cents. hahah
  #28
Old 11-08-2008, 09:11 PM
Normally it would but my "door handle" is so long those remedies would be wasted.
  #29
Old 11-08-2008, 09:39 PM
Quote:
Hmmm..... Doesn't do a thing for what I got sagging!
Julie!
  #30
Old 11-08-2008, 09:42 PM
Quote:
If you go up to the top bar and right click on the thread title, then when the menu pops up, click on "Properties," the URL for the thread is in the center of the page. Highlight it and copy it, then paste it in a word document you have saved for links. Type the title under the pasted URL and all you have to do is double click on the URL on your word document and it will bring you right here!
J!
08 E-150 Door Latch sticks BobRobi 1968-2013 Full Size Vans 2 12-25-2016 06:57 PM
94 F-250 XL Door Sagging Just A Little justplumducky 1987 - 1996 F150 & Larger F-Series Trucks 8 12-05-2016 08:51 PM
1971 C600 Door Latch Joe Kelly 1967 - 1972 F-100 & Larger F-Series Trucks 13 09-20-2016 01:03 PM
Interior door handle - catching hillcountryflt 1967 - 1972 F-100 & Larger F-Series Trucks 3 11-30-2014 01:33 PM
Moving tailgate latch POPAJON 1973 - 1979 F-100 & Larger F-Series Trucks 6 03-01-2011 08:51 AM
Tags
1951, 1960, 48, door, doors, ford, handle, installing, interior, key, lock, locks, removing, sagging, side, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
