Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-10-2008, 07:01 PM
TxFordGuy TxFordGuy is offline
Garage is empty, add now
TxFordGuy is starting off with a positive reputation.
WVO systems
How many out there running WVO on your trucks. Did you make your setup or did you buy the vegistroke. What all do you need to do to the truck to successfully run without problems. i have an 02 powerstroke.
__________________
2002 F-250 Lariat 4x4 CC, 4" Magnaflow SS Exhaust, Wix 6637, Petes Cover, DP-Tuner
  #2 (permalink)
Old 10-11-2008, 11:38 AM
orng1's Avatar
orng1 orng1 is offline
orng1 has a good reputation on FTE.orng1 has a good reputation on FTE.orng1 has a good reputation on FTE.
I am, I've got about 3k running it, have to wait a bit to tell you truthfully there are no probems. I don't have a systen and that's not the safest way to run it but I do mix it with diesel, whatever is in the tank add some oil to it as it's running and go to the gas station to add some diesel on top too. The most important thing is to filter it vey well. I wasn't filtering it that well at first and it smoked more at start up, now it doesn't inless I get impatient and try to start it without waiting to long for the glow plugs to get hot. Now I always wait for the relay to click and it's filtered way better.
__________________
00 F250 5.4L K&N stock box folter, 257k miles.
01 F250 7.3L DP Tuner, Airaid intake, Magnaflow 4" turbo back, 88k miles. Bob
<img src="<a href=http://api.photoshop.com/home_e202e8e80efb4a1696c4980e2d094cf5/adobe-px-assets/c71a8ac8ad5f4072a1981a2a389f6f04 target=_blank>http://api.photoshop.com/home_e202e8...981a2a389f6f04</a>" width="450" height="150"/>
  #3 (permalink)
Old 10-11-2008, 08:28 PM
usherac21 usherac21 is offline
usherac21 is starting off with a positive reputation.
I am running WVO with a Vegistroke system. As far as being turnkey and trouble free, this is the way to go. A lot of peopl ethink it's pricy, and it is, unless you figure what the convenience is worth and what an engine rebuild, injector problems, and the like are worth. I vote for Vegistroke, but I don't have any experience without anything else. Good luck.
__________________
2001 Excursion 4x4 7.3 PSD Vegistroke V3
  #4 (permalink)
Old 10-12-2008, 08:05 PM
Did you instal the vegistroke system yourself? did it come with a parts list? i am just wondering what all is involved in there kit
__________________
  #5 (permalink)
Old 10-13-2008, 08:13 AM
I had the system installed by Pieter Efthiamiatos in Danbury, CT. I saw the kit before it was installed. I understand their tech support is really good. There are several posts on here by people who installed it themselves who said it ony took them one day to do it. The convenience of the install and the service Pieter provided, along with the support he's provided since, really made the extra money for the install worth it. If you want his number to talk to him, just PM me and I can provide it. Good luck.
__________________
  #6 (permalink)
Old 10-13-2008, 09:17 AM
timbrady timbrady is offline
timbrady is starting off with a positive reputation.
I have about 3k on my Vegistroke with no problems at all. You also need a filtration set-up to clean the oil before using it. There are many choices and methods. I went the centrifuge route and have been pleased so far. There are cheaper options though.
I installed the system myself. It's not very complicated, but is challenging due to some of the places you have to put your hands. There is an excellent write-up of an install on the DFA website by a guys named Marv. It lays out what you have to do and has lots of good pictures and tips. Also, the complete installation manual is on the DFA site.
  #7 (permalink)
Old 10-13-2008, 04:44 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud ofSkySkiJason has much to be proud of
Vegistroke is easily installed by anyone w/mechanical ability. Great instructions and customer support is bar-none. Cost? Insignificant really. You WILL get your money back, period. DIY, and ya might have to add some new parts to your broken engine - but you're alot more likely to just wish ya hadn't started about 1/2 way thru. Even then, you may or may not have a conversion that works. The V3 system is just friggin' sweet, all the components are TOP quality and on-par w/OEM fit and finish.
(LOTS of 'average' guys are installing V3 over a weekend, the DFA guru's can allegedly do the under hood plumbing in under an hour!!!!)
BTW, I'm not a salesman for them, just a fan of high quality!
The 'other' options are JUNK. DFA's V3 is the only VO system that capitalizes on the PSD's unique injection system - the so-called competition bandaids a system they patched together for $3-4k Mercedes beaters to a sophisticated late-model PSD truck. (and they look like middle school science projects)
My wife took her Excursion to a Dodge dealership (a friend is parts mgr there) for an oil change a couple weeks ago. The service manager complained because all work in the shop stopped while everyone in the building studied her V3 conversion. Many agreed it could easily have been mistaken for a factory item...
__________________
2001 F350 CC flatbed - Mahle pistons, 910 springs, chromo pushrods, headstuds, AC codes, T4/S366, custom leather interior, '07 facelift, big honkin bumper, 180k miles on DIY veggie conversion and other stuff.
2000 Excursion, Limited, 4x4, BTS trans, Gearhead tunes - wrecked April 2013
  #8 (permalink)
Old 10-13-2008, 06:41 PM
what do you have to filter your oil before you put it in the tank. for those out there running WVO blends, what blends are you running without problems?
__________________
  #9 (permalink)
Old 10-14-2008, 10:17 AM
zhilton's Avatar
zhilton zhilton is offline
2004 Ford F-250
My Garage
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
I'm not running WVO...yet; so this is just my opinion and not experience. One of my next mods to the truck is going to be a Vegistroke V3. I've been trying to read as much as I can about WVO/BIO usage on this site for when I do make the switch...so that I'm a little more informed than the average joe. From what I've been reading, you want to filter the oil down to remove the food particles...along with what else could be in it, as well as remove the water before it goes to the tank on the truck. The filter on the truck is supposed to be a last line of defense before the WVO/BIO goes to the 13 letter combine engine. Maybe I'm mis-informed, but that has been my understanding.
__________________
FTE Arkansas chapter member
1972 Ranchero GT (351C CobraJet intake)
2001 Explorer XLT 2WD
2004 F250 6.0L 2WD CC "Pavement Princess"
2007 Monaco Starwood SL 31BHD
2012 Focus SEL (Wife's ride)
  #10 (permalink)
Old 10-14-2008, 11:35 AM
orng1's Avatar
Yes filter it as best as you can. That's what made the difference in my truck smoking and not smoking in the early mornings. I have a pump with two filters, one is a 2 micron diesel fuel filter and the other is a water seperator both before the pump. I think I'm going to find a 10 micron filter so not to slow it down so much. It does put strain on the pump itself. Temperature and filtering are the most important parts about running WVO. Now I just have to figure out the temperature part...
__________________
  #11 (permalink)
Old 10-17-2008, 05:49 PM
Quote:
'Blending' unheated VO is very bad for your engine. The combustion gasses that get past the rings before engine is at operating temp/full compression are the issue. If those gasses contain diesel, not too big a deal (ever notice how fast your oil gets BLACK in a diesel?). But, if those gasses have unburnt VO, the VO rapidly polymerizes and almost immeadiately lubrication is compromised. Add to that the additional layer of carbon you lay on every day from poorly atomised, marginally combusted 'fuel' during the same time and the damage can be severe.
Usually, UOA will discourage folks from doing this pretty early on - but the damage is not always seen there before its 'too late'. My advice to those blending is to spend some of that money ya think yer savin' on UOA - and please post the results here. You may save some other poor, desperate soul (who's not these days?) from making the same mistake.
__________________
  #12 (permalink)
Old 10-23-2008, 01:17 AM
littledre1 littledre1 is offline
littledre1 is starting off with a positive reputation.
Quote:
If you are in the Northeast and looking to get a Vegistroke system/install I can't say enough good things about Pieter. Install and customer service from him have been top notch. On top of that he's always got lots of oil on hand for sale if you're not interested/don't have the time to collect. PM me for details if you're interested.
As far as the Vegistroke system goes it is AWESOME!!!! I have 10K on the system so far and it has worked perfectly. IMHO if you own a 7.3 there is NO other system that compares to the V3 period!!
Buy it. It's worth every penny.
__________________
~Andre
2000, F350, Lariat, PSD, 4X4, CC, SB, 6spd, Vegistroke, BD Exhaust Brake ,
AIS with Fender Sleeve, SS HPX
315/75r16 Goodyear Duratracs, Milemarker Hydraulic Winch
  #13 (permalink)
Old 10-23-2008, 08:32 PM
dyoungen dyoungen is offline
dyoungen is starting off with a positive reputation.
I have an 1987 Ford F250 with a self installed SVO system. This is the 3rd vehicle I've converted, the other two were Isuzu's. For more SVO information here is another site:
General SVO Discussion - Forum Powered by eve community
  #14 (permalink)
Old 10-24-2008, 09:15 AM
I understand this site has become quite helpful to biodieselers.
I've found the Frybrid site to have the most up to date info on SVO as a fuel available. Check out the VO Theory, Resources, History, etc sections. Good info with lots of references and back-up's for the ideas presented. The forum is full of contributors (mostly DIY'ers) who are quite helpful AND knowlegeable. For the most part, the other sites are 'behind the times'...
__________________
  #15 (permalink)
Old 10-30-2008, 06:06 PM
Jack_99V10 Jack_99V10 is offline
Jack_99V10 is starting off with a positive reputation.
Fellow V3'er here.
Loving every minute of it. The DFA forum is extremely informative and friendly.
I'm Jack_Toepfer over there.
My installation was done by Dan Tanton, Mike Leeder and myself. We completed the entire install front to back and running on WVO in about 5 hours. Dan was the only one with Vegistroke experience.
__________________
2000 F350 CC LB - 250cc 200% - Matt Tuned - 9" Lift - 38" Extreme ATs - Vegistrokin since 08/23/08
http://i2.photobucket.com/albums/y9/...ig_500x100.jpg
Tags
86, blend, ct, dan, f350, ford, idi, installation, manual, pieter, sale, system, tanton, truck, vegistroke, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
