Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-10-2008, 02:53 PM
Blue Bomber's Avatar
Blue Bomber Blue Bomber is offline
Blue Bomber is starting off with a positive reputation.
nOOb question about platinum plugs
why cant you use platinum spark plugs. i know you can't, i just wondered why.
__________________
1974 Ford F-100, Straight 6, 3 speed on the Tree, 2wd. mostly stock....for now!
(10/6) NEwS flaSh: new clutch, new gear oil in the tranny.
thoughts on fixing daily drivers: work now, sleep later
  #2 (permalink)
Old 10-10-2008, 07:41 PM
jarod17's Avatar
jarod17 jarod17 is online now
Nevada CL
jarod17 is gaining momentum as a positive member of FTE.
You just opened up a hornets nest with this one
So I will respond first. I have never had a problem running platinum plugs in any of my trucks. I have never gone beyond regular platinums so I have no input on those. At the same time I never really noticed a performance increase with platinums but I noticed that they did not run as rich on some of my trucks.
__________________
Jeff-Nevada Chapter Leader
Tell me I can't do it or it can't be done I will go out of my way to prove myself right.
People who say it can not be done, should not interrupt those who are doing it. Tom Monson
1996 F-250 4X4 460, 3.55, e40d
1985 D-350 Eventually going to have a Turbo Cummins
1971 F-250 Eventually going to have a 7.3 turbo Powerstroke out of a '99 or newer F-250
  #3 (permalink)
Old 10-11-2008, 08:56 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
Founder ... Stay Tuned
FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation
Plugs should make no difference on A/F ratio since that's a function of carb jetting or EFI tuning. Maybe a more complete burn, but that's not because they are platinum... you'll get a better burn with new copper plugs when you change them (when gapped properly)
The biggest thing you gain with platinums, of the same heat range, is they last a lot longer because they don't suffer from nearly as much gap erosion, meaning you don't have to pull them to regap them periodically for optimal performance. They do this because platinum plugs can use a finer wire and the spark can jump the gap easier from a sharp small metal tip than from a fat flat tip. You can count on about 2-3 times the service life with platinum plugs. Use of platinum plugs is how manufacturers have achieved 100,000 mile change intervals.
__________________
-Ken
If you need to get in touch with me email me at ftsservice at gmail dot com or via AOL IM: motorhavenken.
The best is yet to come....
  #4 (permalink)
Old 10-13-2008, 12:03 PM
sorry guys, i ment to put under boost in there. so the question is really why cant you use platinum plugs in a forced induction engine?
__________________
  #5 (permalink)
Old 10-14-2008, 11:08 AM
bump......
__________________
  #6 (permalink)
Old 10-14-2008, 11:35 AM
FTE Ken's Avatar
It depends on the application. Platinum can be used provided the gap is correct and there is enough output from the coils. Resistance goes up as cylinder pressure goes up, and platinum doesn't conduct as well as copper (for instance) so higher output is sometimes needed. HT0 plugs used in almost all 2004-2008 supercharged 5.4Ls are platinum plugs.
__________________
-Ken
  #7 (permalink)
Old 10-14-2008, 12:20 PM
so copper is best for low voltage systems?
__________________
  #8 (permalink)
Old 10-14-2008, 06:27 PM
FTE Ken's Avatar
Iridium plugs are probably the best option if price doesn't matter (they run about $15 per plug). Doesn't conduct as well as copper but lasts a lot longer, while conducting better than platinum. What vehicle has the blower?
__________________
-Ken
  #9 (permalink)
Old 10-15-2008, 10:51 AM
im tempted to put a junkyard turbo setup on my engine after a good rebuild or engine swap. my friend want me to throw a 300 in it. im just trying to sort everything out before i make up my mind.
__________________
  #10 (permalink)
Old 10-21-2008, 11:50 PM
2000BLK54 2000BLK54 is offline
2000BLK54 is starting off with a positive reputation.
I know a lot of shops run regular copper plugs in their cars. Run them in my truck, friend runs them in his turbo pony, just about most will suggest using them because they work and cost $3/plug. Think the main thing against platinum plugs is that if the engine starts detonating the ground strap won't burn away as quickly as a copper plug's would. If the ground strap goes fast enough then the cylinder shuts down and saves the piston.
__________________
2000 F-150
SuperCab 5.4L, Flareside
S&B, Flowmaster SI/DO, T. Perfomance Dual Electric Fan Kit, ATI ProCharger P-1SC (12 psi), Snow Methanol injection, Jet-Hot full length headers, offroad exhaust
www.cardomain.com/id/2000blk54
  #11 (permalink)
Old 10-22-2008, 10:53 AM
thanks for the info. hows that methanol inj. work for ya?
__________________
  #12 (permalink)
Old 11-21-2008, 02:22 AM
2003F-350SuperDty5.4 2003F-350SuperDty5.4 is offline
2003F-350SuperDty5.4 is starting off with a positive reputation.
One thing to remember for every 50HP, lower the heat range of the plug 1-2 steps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
