DIY Black Headlights Done...again lots of pics...not 56k friendly
Old 10-10-2008, 01:17 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Talking DIY Black Headlights Done...again lots of pics...not 56k friendly
Finally got them done and installed...I have had plenty of time the last few days to work on them
Parts List:
Krylon Fusion Flat Black Paint
300 Grit Sandpaper
2 tubes of outdoor RTV silicone sealant
Painting Masking Tape
Oven at 250F
Out the Door Price...under $10
The Look is awesome IMO.
Stock Shiny Light
Stock Shiny Light Torn Apart
Stock Shiny Light Prepped For Painting
Not So Shiny Light Now
Headlight Installed - Pass Side
Headlight Installed - Driver Side
Full Frontal - Before
Full Frontal - After
now to install this thing
Old 10-10-2008, 01:41 PM
DaMole's Avatar
DaMole
DaMole is offline
Wow that looks good. Those AS blocks are great. I have had them on for about a year now.
Old 10-10-2008, 01:48 PM
BillC's Avatar
BillC
BillC is offline
Professional looking job!
Old 10-10-2008, 06:27 PM
silver05fx4's Avatar
silver05fx4
silver05fx4 is offline
one question i have is
how did you get the light apart b/c arent they glued togetheir
heat gun razor blade ??
Old 10-10-2008, 06:39 PM
o4SCrew's Avatar
o4SCrew
o4SCrew is offline
Nice job!!!
Old 10-10-2008, 09:13 PM
Red04F150's Avatar
Red04F150
Red04F150 is offline
Looks awesome man. Black lights really set off white trucks like yours and mine.
Old 10-10-2008, 09:22 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
oven at 250F
put headlight in for 10 minutes at a time.
carefully pry the lens from the base...reheat periodically to keep the glue hot and pliant
be patient and you'll get there eventually
Old 10-11-2008, 04:53 AM
acfd527's Avatar
acfd527
acfd527 is offline
Looks great! I was going to buy a set that was black, but that sounds easy, and most of all, cheap enough that I may do it myself! Good work
Old 10-12-2008, 05:32 PM
Tk421's Avatar
Tk421
Tk421 is offline
Looks really good. I love the black headlights, however, i have a red truck with the chrome front and rear bumper, and i just dont think the black would look right on mine. The "shiny" stock lights look like they fit i guess.
Old 10-12-2008, 07:21 PM
silver05fx4
im thinking of doing mine silver to match my truck ...i think it should look good
Old 10-13-2008, 12:07 PM
deisele75's Avatar
deisele75
deisele75 is offline
Let us know if you have any issues with traped moisture or leaks. Looks good!
Now you need a set of these to go with it. They look good on a white truck.
Old 10-13-2008, 12:36 PM
98greensi's Avatar
98greensi
98greensi is offline
I've had mine done now for 4 months on my pickup zero issues with moisture. I have had my civic's lights done for 2 1/2 years with zero problemes also. if you do it just make sure to clean out all of the old glue where the two peices seal. one side is a channel, U shaped and the other side just sits in. i used a clear silicon with the tapered tip and filled the channel then sat the other peice in (if your careful enough when you take them apart you, the clips wll still hold the 2 halves together while the silicon dries.)
Old 10-13-2008, 12:38 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
thanks 98greensi...but not for me. I actually really like my OEM FX4's for now
but once my rubber wears out, I'll either buy the Moto Metals 20" rims...or get the 22" Harley wheels. I finally saw a pair in person yesterday on a Black truck with the Orange stripe...I'm in Love. and the chrome/black HD wheels would fit my truck perfectly IMO
somewhere down the road I'll have 20" rims with 35" tires
I also wrapped my lights with string and compressed them for 1 full day until the silicone had fully cured.
Old 10-13-2008, 03:25 PM
Dustin1690's Avatar
Dustin1690
Dustin1690 is offline
Wow that looks pretty good great job
Old 10-13-2008, 09:17 PM
98greensi's Avatar
98greensi
i was brosen around google looking for led lights and came across this pic silver truck with grey lights gives you idea of what it would look like. the chrome grill accent doesn't go with the truck anymore...
Quick Reply: DIY Black Headlights Done...again lots of pics...not 56k friendly
