Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
  #1 (permalink)
Old 10-10-2008, 01:17 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
Talking DIY Black Headlights Done...again lots of pics...not 56k friendly
Finally got them done and installed...I have had plenty of time the last few days to work on them
Parts List:
Krylon Fusion Flat Black Paint
300 Grit Sandpaper
2 tubes of outdoor RTV silicone sealant
Painting Masking Tape
Oven at 250F
Out the Door Price...under $10
The Look is awesome IMO.
Stock Shiny Light
Click the image to open in full size.
Stock Shiny Light Torn Apart
Stock Shiny Light Prepped For Painting
Not So Shiny Light Now
Headlight Installed - Pass Side
Headlight Installed - Driver Side
Full Frontal - Before
Full Frontal - After
now to install this thing
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #2 (permalink)
Old 10-10-2008, 01:41 PM
DaMole's Avatar
DaMole DaMole is offline
2006 Ford F-150
DaMole has a very good reputation on FTE.DaMole has a very good reputation on FTE.DaMole has a very good reputation on FTE.
Wow that looks good. Those AS blocks are great. I have had them on for about a year now.
__________________
Joel
2006 F150 XLT 4X4 - AS 2 1/2 Leveling Kit with AS Blocks, Wet Okole Covers, Volant CAI, Edge Evo, Flowmaster 40 Duals, Husky Toolbox, FX4 Rims & Tires.
1993 F150 XLT 4X4 - 4" Rancho Lift, 33-12.50 BFG, Pioneer Stereo
Proud Club SNL Member #10
  #3 (permalink)
Old 10-10-2008, 01:48 PM
BillC's Avatar
BillC BillC is offline
Garage is empty, add now
BillC is gaining momentum as a positive member of FTE.
Professional looking job!
__________________
Bill
04 F150 XL Reg Cab Long bed
4.6, 3.73, 4wd, Toyo Open Country A/T
Astro bed cap, Toff bedliner
  #4 (permalink)
Old 10-10-2008, 06:27 PM
silver05fx4 silver05fx4 is offline
silver05fx4 is starting off with a positive reputation.
one question i have is
how did you get the light apart b/c arent they glued togetheir
heat gun razor blade ??
__________________
2010 F-150 STX EXT-CAB BLUE FLAME 33" BFG
prev-2009 F-150 FX4 CREW CAB 3.73 E-Locker,
2005 F-150 FX4 35"edge super 40's http://www.ford-trucks.com/forums/album.php?albumid=485
  #5 (permalink)
Old 10-10-2008, 06:39 PM
o4SCrew o4SCrew is offline
o4SCrew is starting off with a positive reputation.
Nice job!!!
__________________
-o4SCrew
__________________
'04 F-150 Supercrew Lariat
"... for all your HID needs!"
DirectJG.com
  #6 (permalink)
Old 10-10-2008, 09:13 PM
Red04F150's Avatar
Red04F150 Red04F150 is offline
Red04F150 is starting off with a positive reputation.
Looks awesome man. Black lights really set off white trucks like yours and mine.
  #7 (permalink)
Old 10-10-2008, 09:22 PM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
oven at 250F
put headlight in for 10 minutes at a time.
carefully pry the lens from the base...reheat periodically to keep the glue hot and pliant
be patient and you'll get there eventually
__________________
  #8 (permalink)
Old 10-11-2008, 04:53 AM
acfd527's Avatar
acfd527 acfd527 is offline
acfd527 is starting off with a positive reputation.
Looks great! I was going to buy a set that was black, but that sounds easy, and most of all, cheap enough that I may do it myself! Good work
  #9 (permalink)
Old 10-12-2008, 05:32 PM
Tk421 Tk421 is offline
Tk421 is starting off with a positive reputation.
Looks really good. I love the black headlights, however, i have a red truck with the chrome front and rear bumper, and i just dont think the black would look right on mine. The "shiny" stock lights look like they fit i guess.
  #10 (permalink)
Old 10-12-2008, 07:21 PM
im thinking of doing mine silver to match my truck ...i think it should look good
__________________
  #11 (permalink)
Old 10-13-2008, 12:07 PM
deisele75's Avatar
deisele75 deisele75 is offline
deisele75 is starting off with a positive reputation.
Let us know if you have any issues with traped moisture or leaks. Looks good!
Now you need a set of these to go with it. They look good on a white truck.
__________________
This is sad...http://www.classiccarsrotting.com/
  #12 (permalink)
Old 10-13-2008, 12:36 PM
98greensi's Avatar
98greensi 98greensi is offline
98greensi is starting off with a positive reputation.
I've had mine done now for 4 months on my pickup zero issues with moisture. I have had my civic's lights done for 2 1/2 years with zero problemes also. if you do it just make sure to clean out all of the old glue where the two peices seal. one side is a channel, U shaped and the other side just sits in. i used a clear silicon with the tapered tip and filled the channel then sat the other peice in (if your careful enough when you take them apart you, the clips wll still hold the 2 halves together while the silicon dries.)
__________________
  #13 (permalink)
Old 10-13-2008, 12:38 PM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
thanks 98greensi...but not for me. I actually really like my OEM FX4's for now
but once my rubber wears out, I'll either buy the Moto Metals 20" rims...or get the 22" Harley wheels. I finally saw a pair in person yesterday on a Black truck with the Orange stripe...I'm in Love. and the chrome/black HD wheels would fit my truck perfectly IMO
somewhere down the road I'll have 20" rims with 35" tires
Quote:
I also wrapped my lights with string and compressed them for 1 full day until the silicone had fully cured.
__________________
  #14 (permalink)
Old 10-13-2008, 03:25 PM
Dustin1690 Dustin1690 is offline
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
Wow that looks pretty good great job
__________________
Dustin - Southern Saskatchewan Canada
My Truck:
1993 F150 XLT Reg cab Long box 351 (5.8L) E4OD 2wd 3.55 non limited slip axle factory ten hole aluminum rims
Dad's Truck:
1992 F150 XLT Supercab Short box 302 (5.0l) E4OD 2wd 3.55 non limited slip axle factory five star wheels
2006 F150 XLT Supercrew 5.5ft box XTR 5.4l 4R75E 3.73 LS 4x4
  #15 (permalink)
Old 10-13-2008, 09:17 PM
98greensi's Avatar
i was brosen around google looking for led lights and came across this pic silver truck with grey lights gives you idea of what it would look like. the chrome grill accent doesn't go with the truck anymore...
__________________
Tags
02, 150, 2010, black, diy, duty, explorer, f150, fox, gun, headlights, heat, mustang, painted, silver, smoked, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
