I have recently finished removing multiple broken exhaust manifold bolts in my 71 534 LN 900. I tried all manner of potions without any luck. i found that heating with an acetyline torch to cherry red, then gently tapping with a hammer to loosen them works sometimes. If unsuccessful, cut off bolts square and carefully centerpunch and drill with increasing diameter drills until you reach 5/16". Then use a 3/8" coarse thread tap and carefully run the tap into the bolt hole. Mine had soft
metal bolts and drilled/tapped easily, except for one that had what I guess was a grade 8 bolt. For this one I had to purchase special solid tungsten carbide drill bits (quite expensive). these worked quite well. If the threads are ruined, they may be repaired with helicoils. Good Luck, It took me about an hour per bolt, after I figured out what I had to do.
