Power steering pump pully - Page 2 - Ford Truck Enthusiasts Forums
Old 10-12-2008, 11:58 PM
stanger53 stanger53 is offline
stanger53 is starting off with a positive reputation.
Snowcat1964
I have a nice D0AR-B pulley that you can have for the cost of postage.
Let me know if you are interested.
stanger53@gmail.com
Old 10-13-2008, 12:03 AM
Snowcat1964, I have a nice D0AR-B pulley you can have for the cost of postage. Let me know if you are interested.
stanger53@gmail.com
Old 10-13-2008, 12:08 AM
Number Dummy, could you please contact me. I need to ask you about some Ford specific parts, but can't find any way to email or PM you.
stanger53@gmail.com
Old 10-20-2008, 08:41 PM
snowcat1964 snowcat1964 is offline
snowcat1964 is starting off with a positive reputation.
Thanks for all the replies I have found a pump with a pully.
Old 09-05-2010, 09:23 PM
Quote:
Originally Posted by NumberDummy View Post
Ford changed the P/S pump design on everything in 1978 except Econolines.
Nothing except the pulleys interchange.
You cannot use a 1978 pump on a 1977 or earlier model, unless you use 1978 type brackets. The earlier brackets will not fit the later pump.
The P/S pressure hose is also different.
The 1978 and later P/S pressure hose has a straight tube on the pump end. This tube has an O-ring on it. Slide the tube into the fitting, then tighen up the nut.
The earlier hoses do not have an O-ring.
The 1978 and later pumps have a plastic reservoir, the 1977 and earlier pumps reservoir is steel.
The dipsticks are also different. 1977 and earlier are steel, with a "shepards" crook in the handle, the 1978 and later dipsticks are plastic and larger in diameter.
All P/S pumps: The P/S pulley must be pressed on/off...it doesn't just slide off.
Hi bill, it has been a while, I got a pully and a pump from a wrecked 1977 ford f100 and ever since i have been fighting it it is wearing out the bellts very fast in like 400 miles it is my hunting rig so usually i dont drive my 77 ford f250 much i have moved the pully in and out trying to solve this issue to know avail i am on my 3rd belt having the same issue it appears to be very close to by eye to be alined correctly... Any sugestions i am about to put back on the aftermarket pump and the old pully that is damaged but it lasts longer than this setup.
Jeff.
Old 07-17-2014, 12:24 PM
elkasdad's Avatar
elkasdad elkasdad is offline
elkasdad is starting off with a positive reputation.
1977 f250 power steering pump pulley part number
I just came from the ford parts desk and verified that c7 p/s pump pulley part number above is obsolete. You can get pulleys for these from dorman for about $20 through orielly or Napa - but its a real bear trying to match up a pulley to the pump unless you have the pump you pulled out. I had a rebuilt ready to go and mistakenly returned the old one for the core charge before solving this pulley issue. Lesson learned...
Old 07-18-2014, 01:29 AM
elkasdad's Avatar
C9TZ-3A733-D Marked: DOAR-B; DOAR-3D673-B / Replaced by > > D9TZ-3A733-A Marked: D9TC-AA; D9TC-3D673-AA.
Applications:
1980/81 351M/400 F150/350 & Bronco w/4WD // 1970/72 302/351C/351W/400 Galaxie/LTD Mercury Marquis // 1973/77 351C(2V)/351M/351W/400 LTD/Mercury Marquis (w/Ford P/S pump only).
1973/76 351C/351W/351M/400 Torino/Merc Montego // 1979 Bronco 351M/400 // 1977 351M/400 F100/350 2WD // 1977/79 351M/400 F100/250 4WD // 1979 351M/400 F350 4WD.
1973/77 F100/150 302 // 1973/77 F100/350 460 w/o A/C // 1969/72 F100 302 w/o A/C.
NumberDummy - Like always, your post is incredibly useful, but I am not seeing our 77 f250 460 2WD w/AC in this list. Attached is a shot I took from the Parts catalog at the Ford dealer today. This is the page for our truck and the part # for that pulley is 3A733 - which I see as part of the "D9TZ-3A733-A" etc above. I am having a hell of a time finding the right pulley for the replacement pump we picked up at O'Reilly, which is this one: MasterProŽ Power Steering 20-6098 - Power Steering Pump | O'Reilly Auto Parts
The two dorman parts pulleys I thought were right 300-102 and 300-122 both have too large a hold for the shaft on this P/S pump. The shaft on this one mics at about .686" internal diameter.
Any help greatly appreciated.
1977 f250 power steering pump catalog part #s
Old 07-18-2014, 11:48 AM
elkasdad's Avatar
77 f250 400 vs 460 P/S pump pulley
I found a pump off a 77 f250 with a 400 here in town but need to determine if that pulley will work on this 3A733 PS pump rebuild I have.
Old 07-20-2014, 12:23 PM
elkasdad's Avatar
1973 F250 460 Power Steering Pump in 1977 F250 460
NumberDummy to the rescue again. I tracked down a P/S pump from a 73 460 and after reading through his list of applications, I determined 73/77 was same P/S pump. I popped that one in yesterday and we're good to go. Thank you.
Some lessons learned:
- Be real careful if you have to pull a pulley. We taco'd ours trying to get it off
- Because of above, and the crazy list of pulley to pump combos, youre probably best off tracking down an entire pump
- We bought a rebuilt pump, thus no pulley, and that sent us on a lengthly chase online and off, to try and find the pulley (since we bent ours trying to pull it off the leaky pump). Once we tracked down a pump with the pulley we needed, since pump was in good shape, we just threw that in rather than risk damaging THAT pulley trying to get it off and put it onto the rebuilt
Serpentine belt/ pully help please kyle j 1994.5 - 1997 7.3L Power Stroke Diesel 9 02-05-2017 06:43 PM
pully jeepy 1961 - 1966 F-100 & Larger F-Series Trucks 9 03-04-2014 03:38 PM
66 F100, got a double pully? johncardi 1961 - 1966 F-100 & Larger F-Series Trucks 11 05-06-2011 07:23 PM
power steering pully Mark-I6 Brakes, Steering, Suspension, Tires, & Wheels 1 05-13-2006 05:10 PM
Help with 1993 Power steering pump pully khab 1987 - 1996 F150 & Larger F-Series Trucks 6 10-12-2002 09:05 PM
Tags
1975, 1977, 351m400, 79, bronco, custom, d9tcaa, d9tz3a733a, f100, f150, f250, ford, power, pulley, pulleys, pully, pump, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
