Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #16 (permalink)
Old 10-18-2012, 10:50 PM
F150on75 F150on75 is offline
Garage is empty, add now
F150on75 is starting off with a positive reputation.
Smile Fun fun fun...
Started removing dash today. Got the core out. Found that the tool for removing the hoses was useless. Hard to put the tool where needed if you can't see it. Cut lines on core and came right out.
Tomorrow the real fun begins putting all the screws back. My helper put them all in one bag. Got to love her anyways.
  #17 (permalink)
Old 10-19-2012, 09:18 AM
Doc's Avatar
Doc Doc is offline
1949 Ford F-Series Pickup
My Garage
Doc has a great reputation on FTE.Doc has a great reputation on FTE.Doc has a great reputation on FTE.Doc has a great reputation on FTE.
Amazingly, the heater hose tool worked for me last weekend. But I can definitely see how it might not.
If you get into a quandry about all of those screws mixed up in the same bag, send me a PM or email and I'll help you sort through it while it's fresh on my mind. As you already know by now, the black screws with the 7mm heads are the dominant fasteners. The longer ones of those go into the kick panel below the steering wheel. You'll definitely remember the three bolts that hold the airbag in place, and the three little tiny 5.5 mm bolts hold the air bag switch in place.
__________________
Shane
1949 F1, Stock / 1950 F-5
1950 F1, 302, AOD (still in a lot of pieces)
1997 F150 XLT, 4.6L
2008 F250 XLT, 6.4L Powerstroke
2011 Expedition EL
  #18 (permalink)
Old 10-20-2012, 05:38 PM
Thanks Doc.
Still working on it. Decided that the door was not the problem and I am replacing the motor while I am in there. Looks like I am in for some fun there. Hope to have that done before I loose anymore light. Love your 49er. Oh for the ease of the less complicated models. I remember as a kid turning the wiper blades from under the dash, when the wiper motor went out. Could not dream of doing that now days. Lol...
  #19 (permalink)
Old 10-21-2012, 04:56 AM
BFTUFF BFTUFF is offline
BFTUFF is starting off with a positive reputation.
The blend door has been redesigned, I would definitely replace it. Also, new foam lining must be adhered to the new heater core before final assembly. Ask your ford parts counter for that. If your replacing the heater core, it's insane not to replace the blend door at the same time, broken or not. it will eventually break or get stuck.
__________________
___________________________
98' F-150 XLT SC 4X4 5.4L E4OD 199,500+ miles.
  #20 (permalink)
Old 10-21-2012, 07:52 AM
Doc's Avatar
Doc Doc is offline
My Garage
Quote:
Exactly. The new blend doors have a round metal sleeve around the lower hinge point. The original WILL eventually break. If you're already in hell, shoot the devil while you're there so that you don't have to go back and do it later.
__________________
Shane
1997 F150 XLT, 4.6L
2011 Expedition EL
Tags
08, 1997, 1998, 1999, 2000, 2003, actuators, blend, core, door, f150, ford, heater, repair, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
