rough idle after head install
I just finished putting the finishing touches on my head swap today. I started it up and it started fine but the idle is extremely rough, the whole engine shakes from side to side. Is this a timing issue or do I have a compression issue? Its a 1981 with the 300. any input is greatly appreciated!!!
Try spraying around the intake-to-head surface with a can of carb cleaner spray while the engine is idling. Try each runner, and be careful not to get it on the exhaust manifold. It may be safer to do this with the motor cold, before the exhaust heats up a lot. If the idle jumps up, then the problem might be a vacuum leak.
I did torque them at TDC....I finally gave up and dropped it at the mechanic, turns out I have one of the worst exhaust leaks he's ever seen. He said it wasnt due to my fault, the manifold needed to be resurfaced and my gasket was probably faulty, should have the truck back by tomorrow! Thanks for all the help guys.
