is this normal?
is this normal?
i got the latest reflash 2 weeks ago and ever since then the truck goes into regen at least once every full tank, if not twice. it never used to do this. i've also noticed more lag on the bottom. should i take it back to the dealer?
also, how do you find out what job# your truck is. just got mine on 08/08/08. thanks...
job # goes by build date. Mine was 03-16-08 so I know it is a job 3. look at the label on the door pillar. you can also ask for a oasis report. do a search on this site and you will find someone to assist. FTEParts guy can do some of this too.
Also sounds like they messed up on the the reflash, mine does not go into regen that often it is not normal, unless you are towing a heavy load.
