Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-07-2008, 06:44 PM
DJOHNSTON78 DJOHNSTON78 is offline
DJOHNSTON78 is starting off with a positive reputation.
Will dome pistons raise ratio and How much in a stock 239
How much will domed pistons raise the compression in 52 239 with stock heads?
  #2 (permalink)
Old 10-12-2008, 09:50 AM
F6Guy F6Guy is offline
F6Guy is starting off with a positive reputation.
to get an exact ratio yo will have to break out your math skills. you will need the compressed gasket thickness combustion chamber volumn and other variables. Your best bet to get an approx. ratio would be to call the piston manufacturer and the will sometimes have a CR for a given head volumn. But it will ultimatly depend on the amount of dome on the piston.
  #3 (permalink)
Old 10-12-2008, 04:09 PM
What is the chamber volume of a stock 239 head 1952.
  #4 (permalink)
Old 10-15-2008, 08:41 PM
that is a good question my repair manual does not say. if you have a head off turn it upside down with a piece of plexiglass with a hole drilled in it placed over the chamber. Then get an eye dropper and measure how many cc's of water or oil or whatever liquid it taked to fill it up.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
