new inline heater - Ford Truck Enthusiasts Forums
new inline heater
Old 10-06-2008, 10:22 PM
MAKO314's Avatar
MAKO314 MAKO314 is offline
MAKO314 has a good reputation on FTE.MAKO314 has a good reputation on FTE.
new inline heater
these are some pics of a new inline heater that I made. it works great and is a antisiphoning design. it heats 50 gal of oil to about 130 to 140*F in about 20 minutes.
Old 10-07-2008, 12:36 AM
orng1's Avatar
orng1 orng1 is offline
orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.orng1 has a great reputation on FTE.
What are you using it on? What are you using to heat the oil? Can you explain how it works?
Old 10-07-2008, 05:50 AM
MAKO314's Avatar
it's on my processor and it has a 4000 watt heater element in the end of it
Old 10-07-2008, 12:30 PM
orng1's Avatar
So it has a heater element in it, cool. It plugs in, take another picture from the other side. I'm always trying to see what others are using. I use a propane BBQ and let it sit at low over night. I used to be able to use that BBQ but I don't feel so bad because I got it for free.
Old 10-07-2008, 09:44 PM
MAKO314's Avatar
here's another pic
Old 10-08-2008, 12:46 AM
orng1's Avatar
LOL thanks, that actually helps a lot. Now where can I find one of those heaters? I like the description of everything, how long did you spend in the hardware store looking for everything?
Old 10-08-2008, 08:15 AM
MAKO314's Avatar
I was in lowes for about 15 minutes
Old 10-11-2008, 02:26 PM
zhilton's Avatar
zhilton zhilton is offline
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
Does it matter which way the oil flows past the element? I'm assuming it doesn't, but you never know if one way works better than another. I'm going out on a limb saying you've got less than $25 in the entire heater. I like that simple design.
Old 10-11-2008, 08:30 PM
MAKO314's Avatar
I have the flow going FROM the elbo TO the T with the element in it. I did it this way so I could mount the heater horizontal with it a little lower at the element to avoid an air pocket that would greatly shorten the element life, mounted in this way the element is always completely submerged even when the pump is shut off. the only draw back is the houseing will collect a small amount of glycerol so after draining your reactor of glycerol run the pump for a second or two to clear the housing. this is not my design but it is a great one that works well. the oil must be circulated through the heater while it is on or I don't know what will happen but it can't be good. I have my heater wired in with the pump so one will not run without the other. you're close I think element and all it might have been 40.00, I used all black steel pipe instead of galvanized..
Old 10-12-2008, 09:50 AM
westcoastslider's Avatar
westcoastslider westcoastslider is offline
westcoastslider is starting off with a positive reputation.
Quote:
I think that was a good call. Galvanized doesn't react well with diesel or VO so I don't imagine it would be any better for bio.
Old 10-16-2008, 06:28 AM
TchTchr TchTchr is offline
TchTchr is starting off with a positive reputation.
Quote:
I wondered about the galvanized pipe also. BTW, my Lowe's doesn't have black pipe in the 2" variety. Any idea where else to get it?
Thanks
Old 10-16-2008, 04:42 PM
MAKO314's Avatar
Ace hardware should have it, lowes can get it you may have to order it. also a 1 1/4 pipe will work it just doesn't heat as fast because of the faster flow rate
Old 10-17-2008, 05:30 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
Yes, its true galvanizing and VO do not get along well. The galvanizing comes off and the flakes are a wonderful 'oxident' to the VO, rapidly increasing the rate of polymerization. IOW, the 'fuel' won't last as long and will use more filters (due to early-stage poly)...
I have sand-blasted the insides of some galv pipe to remove the offensive coating!
Also, be aware that locallized overheating is possible (due to laminar flow), creating little carbon chunks that must be filtered out. But, since most elements that size are 220v - the wattage is only 1/4 that rating at 110v, so the 4k watt element is prolly OK after all - depending on the flow of oil thru the 'heater'.
I've used a set-up almost just like the pics for over 2 yrs now - with and without a water heater t-stat attached to the pipe. Someone over at DFA forums posted a cool t-stat controlled 'immersion heater' from mcmaster they were using in same fashion. (nice, but looked pricey!)
classic inlines Kendal 1967 - 1972 F-100 & Larger F-Series Trucks 11 03-10-2017 06:25 AM
new here need help with my 1996 ford f150 stevew1176 New Member Introductions 0 08-10-2015 11:57 PM
Heater switch resistor mtnone 1961 - 1966 F-100 & Larger F-Series Trucks 10 10-14-2012 09:20 PM
Fuel Heater on 1983 6.9L diesel eichenlaub 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 02-19-2012 10:27 AM
Cab Heater bearqst 6.7L Power Stroke Diesel 54 12-16-2011 03:23 PM
Tags
1997, 50, cummins, destroked, diesel, explorer, heater, immersion, inline, limited, pics, processor, road, trucks, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
