Weld Wheels Center Cap Info.
Good luck, Last I heard Weld Wheels went bankrupt last year (or year before??). Someone may have bought them, not sure but I did get a letter a while back from bankruptcy attorney asking if they owned me any money and to file a claim (I was a Weld dealer at the time).
EDIT: Google search shows ARE (American Racing Equipment) bought their assets so they have resurected/saved the brand.
DC,yea they have the tapped holes with the plugs in them just like my Scorpio's did.Yea,they came with the black snap in caps.I got these for cheap from 4WheelParts last month when they were clearing them out 75% off.Do you know where i can get the brushed finish conehead's are know the part# i would appreciate any help in finding a set new or used.
Damn,i just went in the Garage and looked 2 of the wheels have the tapped holes and 2 dont I hope they didn't send me two that fit something else.I already had tire's mounted on them waiting on the truck to be lifted.Is there anyway to measure the lug pattern without having the truck here to trial fit.
Looks like im stuck using the snap in centers though.
Measure from the center of the hole to the center of the hole in the 12 o'clock and 6 o'clock positions.
Basically measure center to center on two lug holes that are directly across from each other.
SD bolt pattern is 8x170mm
170mm=6.6929"
So the distance should be 6.6929".
Only other 8lug they'd have would be the 8x6.5" So it would be easy to tell.
Those Methods you pictured appear to have a real bead lock ring....vs. a faux bead lock ring on the regular Methods.
I picked up (as did a few of my friends) some 20x12 Methods during that sale since they were well below cost on those wheels. None of mine are tapped.
170mm=6.6929"
170mm=6.6929"
170mm=6.6929"
I thought those bead lock rings were an option Weld offered called pro-loc are something.They Look real but were not are the screws in the ones we have not removable i thought you took the screws out to install those.
86F150302
26
12-30-2016 08:25 PM
breckman99
07-26-2010 05:59 PM
