Emergency Brake Cable Tension
I have a 1993 F150, long bed, 300 i-6
My emergency brake cable broke at the pedal. I can't seem to figure out how to get the cable adjuster to release to get some slack in the system.
I believe the adjuster is in the pedal assy itself, buy am not 100% sure.
Thanks,
Paul
Thanks,
Paul
If the cable broke at the pedal why don't you have all kinds of slack in the cable?
My 94 has no provision to adjust the cable anywhere, I doubt a 93 does either. The point just outside the frame on the drivers side only allows one cable to pull two equally, no adjustment there whatsoever.
on
1 Post
that equalizer is adjustable - thats how you assemble it!
its probably rusted to crap. ford does that well.
but anyways, in a non-rusted-to-crap unit you hold the end of the 'rod' that is threaded - a CWFH (crescent wrench from hell) works good, and then spin off the nut on the end of the rod. but again - the rust.
now for your front cable, the one from the EQ to the pedal - it is available commercially and the installation procedure is kinda a pain, u really need to pull the carpet out of the way, and if it rusts at the firewall - ick
Here is how I fixed it
For those that are interested...
There is no tensioner on any of the cables.
I took some photo's out of the truck for clarity. You shouldn't have to remove it
The brake pedal assy looks like this (pedal is part way down):
There is a small white part near the pedal arm, this was holding back the e-brake adjustment for me:
I pried out this white part (screwdriver) completely and that loosened the cable tensioner assy in the pedal. The cable was still short, but with the white part out, the cable would pull out on a spring mechanism. Here is a photo with the part almost out:
The part can be put most of the way back in by hand, but releasing the e-brake will force it the rest of the way in:
That's how my 1993 F150 worked... your mileage may vary.
Eddillard79
10-09-2014 07:15 PM
96expblk
02-02-2007 03:51 PM
