what am i doing wrong
25gal oil
5 gal methanol
tirated 1.5, tested 3 times with same results(digital ph meter calibrated before every use)
base of 7.8KOH=9.3g/L
881g of KOH
i use a plastic conical tank hooked up to a 320GPH HB pump. heated oil to 130deg. added methoxide over a 20min period and mixed for 2hours. it has settle now for 32 hours and i only see a little over 4gal of glycerin sitting in there. every batch seems to be this way. whats my problem
5 gal methanol
881g of KOH
every batch I make produces anywhere from 10 to 15 % of the total liquid volume of glycerol.this percentage depends on your titration #. your results sound close. do the 3/27 test to check for unreacted oil, it will tell you if you're getting a good crack or not. I also give up the KOH thing just because I could'nt get a full reaction. the NaOH is much more volitile and a lot less forgiving but I feel you get better and faster results once you get it right.
oh yeah I havn't forgot about the filter pics I just renewed my site dues so I'll be able to post pics for everyone. I got the filter tank from the Rainsoft dealer in Charlotte and the activated carbon from piedmont clorinator service in Charlotte NC
We're in Winston Salem, may want to come down and check out how you do things and get some suggestions. I'm brand new to this, my neighbor has a conical, plastic processor and has done about a dozen batches with KOH - we are looking for ways to be more efficient. Also looking to build a good collector pump system as we have a few restaurants set up but will need to pump out of 55's on the ground into 55's in the back of my F350. How do you handle that?
Thanks
Tom
Hey MAKO,
Thanks
Tom
Thanks
Tom
