Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-05-2008, 06:56 PM
Ego Flat 48 Ego Flat 48 is offline
Ego Flat 48 is starting off with a positive reputation.
Cooked my goose, I mean my coil.
OK guys are you ready for some humor? I have a flathead 239 on a stand with a radiator hooked up to it. I am trying to get it running but it will only run when I squirt gasoline into the carb. My fuel pump is not pumping to the carb. Can someone please tell me why. I bought a new fuel pump and changed the guts and put into my original one. You know, old, original serial #s, etc.
Problem number two:
I was told that I could run a wire from the battery side of the coil to the positive side of the battery to try to start it. Well. I did that. And after a few minutes I cooked my coil. They do not smell good when fried. Hee Hee. Anyway did I leave this wire on too long? Please advise. I'm just glad it wasn't my new MSB 8200 coil. Thanks in advance. Ralph
  #2 (permalink)
Old 10-05-2008, 07:33 PM
4x4lugnut 4x4lugnut is offline
4x4lugnut is starting off with a positive reputation.
You said it would run when you squirted gas into the carb, right? You also said that you put the guts from a new fuel pump into the original, did you try the pump by hand to make sure it worked correctly before you installed it on the engine. If it did the problem is a worn fuel pump rod, they wear and will not push the fuel pump arm far enough to make it pump. An old timers trick back in the day was to cut a piece of leather from the tongue of a shoe and put a small piece of it on top of the rod to help take up the slack. If you fix your electrical problems and you are sure your pump is good, a new rod will probably get you running!
  #3 (permalink)
Old 10-05-2008, 08:07 PM
Have been thinking about your wiring issue. If I recall I ran a 32 ford with a 37 engine for years without a switch. I would hook a wire directly to the battery but before it went straight to the coil, it had to go through a resistor on the firewall. Might save another coil!!!!
  #4 (permalink)
Old 10-06-2008, 10:27 AM
Cooked coil
4x4:
Yes, it will run only when I squirt gas into the carb. So gas is not going to carb from fuel pump. As far as checking the fuel pump for working condition prior installation, I moved the pump arm up and down and with my limited knowledge, it seemed to work. Please inlighten me if I should have done something else.
As far as the pump rod being long enough: I measured it to be 1/16th of an inch shorter than a new one. Would 1/16th make a difference. Sounds like it would as thats about the thickness of a shoe tongue.
The wiring issue:
Should I have removed the wire from the coil to the positive side of the battery as soon as if starts? Or is it even needed? Copy that on the resister.
4x4; I really appreciate your time in helping me with this.I wish I had learned more from my Dad. I miss him. Ralph
  #5 (permalink)
Old 10-06-2008, 08:10 PM
Cooked coil
4x4 lugnut;
Guess what I found out? The original coil on the v8 was a 6 volt. I hooked to a 12 volt battery...I did not have a clue it was 6 volt. Learn something everyday. Bought a new coil and resister today and will try again. Will let you know what happens. Also, I took the fuel pump and discovered the round hole in the arm was oblong unlike the original. So I put the old one back in. We'll see what happens. Ralph
  #6 (permalink)
Old 10-08-2008, 11:40 AM
Sounds like you might be able to hear the old flathead running again soon. Good luck. By the way, I still have the ol 32, need to get it out and see if I can get it fired up. Nothing like the sound of a good ol ford flathead!
  #7 (permalink)
Old 10-08-2008, 04:33 PM
Cooked coil
4x4lugnut and j;
Guess what I learned? I'm so excited to share this......It's new to me but I never claimed to be a mechanic. I found out why my fuel pump wasn't pumping. On the top inside of the pump are two dime sized diaphragms. They were both in wrong. One has to be facing in and the other facing out.The one on the right faces in and the one on the left faces out. I'm not sure if it matters which way it goes, but thats how I did it. Anyway, I put it back together and it pumps good, and engine sounds like a sherman tank with no mufflers. I learned this by reading a 2005 thread on the Forum. Thanks for all the help....Ralph.
  #8 (permalink)
Old 10-12-2008, 02:19 AM
Hades212 Hades212 is offline
Hades212 is starting off with a positive reputation.
What are you gonna put that flattie in Ralph?
  #9 (permalink)
Old 10-12-2008, 06:24 PM
Next up
Hades212:
The flathead is going into 'a 48 Ford F1. First, I have to pull out a beautiful running 226 that I just had completely rebuilt. It runs like a sewing machine. I just want a flathead. You know its an old time thing. I want to hook it to a c4 tranny, chevy s10, 5 spd, but also considering using my old 4 speed tranny. But, I want to be able to stomp on it and drive on the freeway @ 60mph. Got lots to learn. The flathead had been setting for 42 yrs. and it started right up with just a few minor adjustments. And of course, listening to old country music. Thanks for asking. Ralph.
  #10 (permalink)
Old 10-12-2008, 08:17 PM
Oakroadjoe Oakroadjoe is offline
Oakroadjoe is starting off with a positive reputation.
What are your plans for the 226? Might be interested.Need a reason to visit mo. val.
  #11 (permalink)
Old 10-12-2008, 11:54 PM
What adapter plate are you gonna use to hook up that flattie to the s10 tranny.
  #12 (permalink)
Old 10-13-2008, 05:25 AM
Cooked coil
Oakridgejoe:
I plan on selling the 226. If you are interested perhaps we can work something out. I also have a rebuilt radiator and an original 4 spd tranny. Plus extras.
Hades212. Not sure what adapter I will be using. I haven't finished researching it yet. Would like to use the original bell housing if possible.But I don't know if it's even possible. Any suggestions?
  #13 (permalink)
Old 10-13-2008, 06:23 PM
If you can p m me we can talk about your stuff.
  #14 (permalink)
Old 10-14-2008, 07:25 PM
If you get someone who wants the engine,do it. If i ever get mine running i would not need yours. If i have problems yours would be the answer. I am meeting someone this weekend at the turlock auto swap with a radiator(???) if it is good i would not need yours .Again if you get buyers,SELL .We go thru Redlands going to Moreno Valley(daughter lives there) so it would be a simple pickup.Thanks Joe
  #15 (permalink)
Old 10-14-2008, 07:41 PM
effie_man's Avatar
effie_man effie_man is offline
Fatty driving the Flatty!
effie_man is gaining momentum as a positive member of FTE.
congrats on getting your flattying firing again. let us know about your research into the s10 and the c4 tranny conversions, some people would be interested in hearing it (me!!!) lol
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
