Dana 60 4x4? 95 F-350
since the axles are coming out I recommend these too...
Dana 60 Outer Axle Seal [D60-OuterSeal] - $55.00 : Mad 4 Wheel Drive, Bulletproof Offroad Parts & Custom Axle Assemblies
The seal can be damaged very easily...two people make it a little easier.
The best method is get the right tool or make one.
More:
https://www.ford-trucks.com/forums/7...placement.html
Jaaaaaaackman
Just pulling the center section out won't change any of the clearances, just made sure you put the bearing caps back on exactly the way they come of. The easiest way to remove the carrier is with a case spreader but I've never had one side I just pry them out with a small prybar. My friend did his with a comealong attached to the front bumper. My axles were chained on a flatbed so that wasn't an option for me.
ron86toy
I've never seem them outer seals before, are they new? I wish I knew about them when I rebuilt mine.
Cuda_jim
That's kinda what I did. I used a piece of black pipe and a big socket to tap the pass side seal in and then the same pipe with a floor flange screwed on the end to pull in the drivers side seal
ron86toy
Cuda_jim
They have been out for quite a while...been running them in the trail truck for 3 yrs or so....keeps all the crap out of the tubes and saves the inner seals.Well worth the money.
djbonsu
01-12-2021 01:59 PM
Radster
12-05-2016 01:20 PM
