Ranger curb weight??? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-05-2008, 07:52 AM
meck1 meck1 is offline
meck1 is starting off with a positive reputation.
Can anyone tell me the approximate curb weight of a '94 Ranger, extended cab, with the 2.3L, five speed? Thanks.
Old 10-05-2008, 07:38 PM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
My 1999 4x2 supercab with the four cyl and 5speed has been weighed at 3500# with half tank of gas.
Old 10-05-2008, 07:47 PM
Rangerman Stan Rangerman Stan is offline
Rangerman Stan is starting off with a positive reputation.
meck1, you should be around 3200 lbs, give or take 100lbs for the 94.
Old 10-05-2008, 07:50 PM
jv42287 jv42287 is offline
jv42287 is starting off with a positive reputation.
Check the sticker in the door jam on your driver's side. It should have the weight there with the tire pressure info. At least my 97 has it there.
Old 10-05-2008, 08:27 PM
Thanks for the estimates. The door jamb label gives gross vehicle and axle weights when what I was looking for was the unloaded weight of the vehicle.
Old 10-05-2008, 08:30 PM
sorry about that, just trying to help.
Old 10-05-2008, 09:22 PM
Scolesy8's Avatar
Scolesy8 Scolesy8 is offline
Scolesy8 is starting off with a positive reputation.
well, my 99 ranger has the 3.0L v6 supercab and 4wd, and on a half-3/4 tank its about 4020lbs
Old 10-05-2008, 11:00 PM
sfcwoodret sfcwoodret is offline
sfcwoodret is starting off with a positive reputation.
That's a heavy Ranger!
Old 10-07-2008, 02:26 AM
racsan's Avatar
racsan racsan is offline
racsan is gaining momentum as a positive member of FTE.racsan is gaining momentum as a positive member of FTE.
my '93 4x4 4.0 5 speed weighs 4,300 empty.
1985 f350 4 door dually curb weight? MUSKRATT2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 11-03-2012 10:17 PM
Curb weight of a 1948 f6 fisherman_chuck 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 07-04-2012 05:36 PM
2006 F250 curb weight tippmann87 6.0L Power Stroke Diesel 1 12-29-2007 12:51 AM
approximation Base Curb Wt stupidmonkey Ranger & B-Series 5 08-23-2005 03:28 PM
Curb Weight Silver02 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-16-2005 01:10 PM
Tags
1985, 23, 85, 94, curb, ford, ranger, weight, weights
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
