Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-03-2008, 03:17 PM
H1449-6 H1449-6 is offline
Garage is empty, add now
H1449-6 is gaining momentum as a positive member of FTE.
Optimal blend of bio for lubricity?
I'm not going to be able to use soybean B100 any more now that it's getting cold. I do want to retain the cleaning and lubricity benefits if I can though.
What's the optimal percentage of bio to run for those benefits? Can I get it at B10-20? Or do I need a stronger blend? I think I can realistically run up to about B50 for another couple of months. Once the winter really hits (typical temperatures in the low teens) I'm at no more than B20 if that.
Thanks.
__________________
2003 7.3L PSD Excursion Limited 4x4
MBRP 4" stainless exhaust, Hellwig bar, DP-Tuner
  #2 (permalink)
Old 10-03-2008, 06:00 PM
jmaskew's Avatar
jmaskew jmaskew is offline
jmaskew has a good reputation on FTE.jmaskew has a good reputation on FTE.
From what I've read B2 is all you need for lubricity.
__________________
Jonathan
2004 F250 PSD SB King Ranch 4x4:Build Date: 01/23/2004
Dieselsite Coolant Bypass Filter, High Idle Mod
Fumoto Oil Drain Valve, Harpoon Mod, Zoodad
Isspro 40 PSI Boost, Water Temp, Oil Temp, Trans Temp, Volt and EGT
  #3 (permalink)
Old 10-03-2008, 07:41 PM
slowmans's Avatar
slowmans slowmans is offline
slowmans is gaining momentum as a positive member of FTE.slowmans is gaining momentum as a positive member of FTE.
ditto! but I run b-5 in the boston winters
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
