Fuel leak at two wire plug housing NEXT to yellow fuel drain valve.
Noticed a faint smell & small fuel puddle under engine. First thought was the o-rings leaking at yellow fuel drain but instead it's a slow drip coming from this two wire plug next to the fuel drain. It looks like a housing held on by a couple screws and two wires coming out of it. A search tells me the wires are for the fuel heater and possibly water in fuel sensor. Wires look like red/tan stripe and the other tan/red stripe, hard to tell for sure. Am I on the right track here, has anybody else had this problem and how do I fix it? If it is just o-rings what size are they?
Pictures would be helpful. My first thought was the fuel bowl heater too, but I've never had one of those apart. In case it's the water sensor the o-rings are as follows.
Water in Fuel Sensor (Large) Viton 3/32" 5/16" 1/2" Dash size # -109 Ford part # F81Z-9C065- AA
Water In FuelSensor (Small) Viton 3/32" 3/16" 3/8" Dash size # -106 Ford part #F81Z-9C065-AA
OK, I managed to create a gallery and upload a pic to it. Click my name and then click my gallery and you can see the pic, the leak is coming from the housing to the left of where the screwdriver is resting. It isn't the best pic but there are 2 screws that I can easily see (maybe another one I can't). If I try to remove this is it connected to something inside the filter housing or will it come along "peacefully"?
Well you may be a first. That looks to be the fuel bowl heater connection plug and I don't recall seeing a leak from there. You may be breaking new ground here.
There are several fuel bowl delete folks that may be able to tell you what it can and cannot be based on looking at their unit out of the truck. Mine is still in the truck.
EDIT: IOW bump.
EDIT: IOW bump.
Brandon those pics were most helpful, thanks a whole bunch.
I drained the bowl, took out my filter and unplugged the wire from the inside. Then I removed the water in fuel/fuel heater plug. The two o-rings didn't look that bad but the body of the plug was warped and looked like it got hot & cooked. When I was blowing it clean with air I was getting air/fuel blowing through the body. I took pics and have them in my gallery, they show the warpage (is that a word?) on the top side of the plug and the bottom of it still looks good. I now need to get a new part, or, does anyone make a kit to cap it off? I'll do a search on this, right now I want to fix the leak, I don't care about the fuel heater or the water in fuel feature.
Thanks again for the help. As Tenn01PSD350 said I "may be breaking new ground here". Maybe someone else will have this problem and get some good from my "ground breaking".
hold one, let me go outside and see if that old fuel bowl is still on my workbench, and I will look at the plug and see if it is any good. If so you may have it. be right back..........
Yep, its out there, and the plug looks good, PM me your address and I will send it out Monday.
No charge, its the FTE Way, If you have something you are not using, pass it on to someone who needs it.
Let me know.
Let me know.
on
1 Post
Don't think there's anyway to read what the comments are, but each 100 rep points you receive gets you another green chiclet. When someone with a whole bunch of chiclets awards you with a compliment the more points go towards your 100 points. Now you know as much as I do.
yeah mine is leaking also, it is leaking through the plug. it came out easy. i could not find any one that carried it but ford. those mf ers want 140 some odd dollars for the hole unit. it would steam or smoke while it was plugged in. it didn't smell like smoke but sure looked it. i unplugged it and every thing seems fine for now.
