04 F150 Howling from 30 to 80mph
I have a 04 F150 that has a serious howl between speeds of 30 and 80 mph, it goes away if you let up on the accelerator. I pulled the rear end pan off and replaced the fluid, all the gears looked good. Drive shaft seems tight, I pulled the drive shaft off and test drove a short distance with the front drive shaft and no howl. Anyone experience this?
TSB 05-23-3
ISSUE:
Some vehicles may exhibit an axle whine or hum during acceleration, deceleration and/or cruise.
ACTION:
An axle repair kit has been developed which incorporates most parts required for a comprehensive axle repair. The kit should be used instead of installing a complete axle assembly to repair an axle whine/hum. Replace Ring and Pinion with Axle Kit and Components.
<table border="0"><tbody><tr><td width="80">NOTE:</td><td>REFER TO THE "DIFFERENTIAL RING AND PINION" IN-VEHICLE REPAIR PROCEDURE IN THE ONLINE WORKSHOP MANUAL SECTION 205-00, FOR THE LATEST AXLE DIAGNOSIS AND REPAIR PROCEDURES.</td></tr></tbody></table>
<table border="0"><tbody><tr><td width="80">NOTE:</td><td>FOR 1999 AND PRIOR MODEL YEAR VEHICLES, USE THE 2000 MODEL YEAR WORKSHOP MANUAL.</td></tr></tbody></table>
<table border="0"><tbody><tr><td width="80">NOTE:</td><td>WHEN SERVICING THE REAR AXLE ON ANY 2002-2004 F-150, EXPEDITION, NAVIGATOR, EXPLORER OR MOUNTAINEER BUILT BEFORE 3/30/2004, IF FLUID REPLACEMENT IS REQUIRED, REPLACE THE ORIGINAL FUEL EFFICIENT HIGH PERFORMANCE (FEHP) SAE 75W-90 REAR AXLE LUBRICANT WITH SAE 75W-140 HIGH PERFORMANCE SYNTHETIC REAR AXLE LUBRICANT. WHEN THE FLUID TYPE IS CHANGED, REPLACE THE CURRENT "FEHP" METAL TAG WITH A NEW "75W-140" TAG (F3TZ-4121-AA). IN ADDITION, REMOVE OR BLOCK-OUT THE FEHP REFERENCE ON THE MULTI-COLORED LABEL LOCATED ON THE RIGHT SIDE AXLE TUBE. IF THE AXLE IS A LIMITED-SLIP MODEL, USE XL3 ADDITIVE FRICTION MODIFIER IN THE QUANTITY RECOMMENDED BY THE WORKSHOP MANUAL.</td></tr></tbody></table>
KIT ORDERING: REFER TO THE VEHICLE AXLE TAG FOR AXLE RATIO IDENTIFICATION
THE AXLE SERVICE KITS INCLUDE THE FOLLOWING COMPONENTS:
ORDER AS NEEDED:
<table border="0"><tbody><tr><td width="80">NOTE:</td><td>REUSE OF RING GEAR BOLTS, CARRIER BEARING CAP BOLTS AND DIFFERENTIAL SLAVE PIN RETAINING BOLT REQUIRES CLEANING OF THREADS AND INSTALLATION OF TA-27 STUD AND BEARING MOUNT RETAINING COMPOUND & SEALANT.</td></tr></tbody></table>
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
<table border="1" cellpadding="3" cellspacing="0"> <tbody><tr> <th align="center">OPERATION</th> <th align="center">DESCRIPTION</th> <th align="center">TIME</th></tr> <tr> <td align="left">052303A</td><td align="left">1997-2002 Expedition, 1998-2002 Navigator, 1997-2004 F-150 Heritage, 2004-2005 F-150: Rear Axle Noise Repair (Includes Time For Road Test To Verify Concern (Beam Axle)) (Do Not Use With 4205A Or 4205A4)</td><td align="left">4.7 Hrs.</td> </tr><tr> <td align="left">052303A</td><td align="left">2003-2005 Expedition: Rear Axle Noise Repair (Includes Time For Road Test To Verify Concern (Irs Axle)) (Do Not Use With 4010D Or 4010D4)</td><td align="left">5.8 Hrs.</td> </tr><tr> <td align="left">052303A</td><td align="left">2003-2005 Expedition/Navigator With Air Suspension: Rear Axle Noise Repair (Includes Time For Road Test To Verify Concern (Irs Axle)) (Do Not Use With 4010D Or 4010D4)</td><td align="left">5.9 Hrs.</td> </tr><tr> <td align="left">052303A</td><td align="left">2002-2005 Explorer/Mountaineer, 2003-2005 Aviator: Rear Axle Noise Repair (Includes Time For Road Test To Verify Concern (Irs Axle)) (Do Not Use With 4010D Or 4010D4)</td><td align="left">6.6 Hrs.</td> </tr></tbody></table> DEALER CODING
<table border="1" cellpadding="3" cellspacing="0"><tbody><tr> <th align="center">BASIC PART NO.</th> <th align="center">CONDITION CODE</th></tr> <tr><td align="center">4209</td> <td align="center">14</td></tr></tbody></table>
ISSUE:
ACTION:
- 5L3Z-4209-A = (8.8-Inch Ring Gear/3.31 ratio) (1997-2005 F-150)
- 5L3Z-4209-B = (8.8-Inch Ring Gear/3.55 ratio) (1997-2005 F-150, 2002-2005 Explorer/Mountaineer/Aviator)
- 5L3Z-4209-C = (8.8-Inch Ring Gear/3.73 ratio) (1997-2005 F-150, 2002-2005 Explorer/Mountaineer/Aviator, 2003-2004 Expedition/Navigator)
- 5L3Z-4209-D = (9.75-Inch Ring Gear/3.31 ratio) (1997-2005 F-150, 2005 Expedition/Navigator, 1997-2002 Expedition/Navigator)
- 5L3Z-4209-E = (9.75-Inch Ring Gear/3.55 ratio) (1997-2005 F-150, 1997-2002 Expedition/Navigator)
- 5L3Z-4209-F = (9.75-Inch Ring Gear/3.73 ratio) (1997-2005 F-150, 1997-2005 Expedition/Navigator)
- 4630 - Head Bearing
- 4628 - Head Bearing Cup
- 4676 - Pinion Seal
- 386989-S2 - Washer (Slinger)
- 4621 - Tail Bearing
- 4616 - Tail Bearing Cup
- 4222 - Differential Bearing Cups
- 4221 - Differential Bearings
- 4209 - Gear Set (includes pinion shims, pinion nut and crush spacer)
- 4209 - Instruction Sheet
ORDER AS NEEDED:
- YL3Z-4662-CA - Pinion Bearing Spacer for 1997-1998 9.75 axles
- XG-14 - Gear Marking Compound
- 4067 - Differential Shims 0.241" to 0.307"
- SAE XY-75W140-QL - High Performance Synthetic Rear Axle Lubricant
- XL-3 - Additive Friction Modifier (Limited Slip Axles Only)
- 205-506 - Seal Protectors (Rotunda Tool)
- W710084-S439 - Wheel End Nuts
- 390266-S100 - Differential Slave Pin Bolt (9.75" axles)
- 387426-S100 - Differential Slave Pin Bolt (8.8" axles)
- 4B422 - Axle Circlips
- ZC-21 - Metal Surface Cleaner
- TA-29 - Ultra Silicone Sealant
- TA-27 - Stud and Bearing Mount Retaining Compound and Sealer
- F3TZ-4121-AA - Fluid Tag (REQUIRED IF FLUID TYPE IS CHANGED FROM FEHP DURING REPAIR)
powerstroker100
1999 to 2016 Super Duty
15
03-20-2012 10:41 AM
mechelement
23
05-27-2010 07:28 PM
