Offroad & 4x4
Gear Ratios and where to get them done...
Old 08-30-2001, 07:09 AM
KPO's Avatar
KPO
KPO is offline
Old 09-10-2001, 12:34 PM
theleetbeagle's Avatar
theleetbeagle
theleetbeagle is offline
Hi. I will be upgrading my truck to a 6" lift (currently has a 3" body lift) and will be putting 35" tires on it. Currently has 30.5" and it doesn't like getting them rolling from a dead stop. I believe I have 2.73 gears in the rear end. With my Mazda five speed (yes, 2WD) what should I have swapped in? I'm thinking 4.11's? I would love feedback on what you think I should put in.
Mild off roading (2WD, remember), daily driver, some highway.
Has OD.
Also, in the North East Ohio area...does anyone know of a shop that can do this work?
Thanks!
-Nick.
Old 09-10-2001, 01:43 PM
nick1's Avatar
nick1
nick1 is offline
I would go with 4.11's since its a daily driver, but it also depends on the motor your running or plan on running in the future. 4.11's and 35's put my rpm's back to where they were with stock tires and 3.50's. If you have overdrive or a weak V6, you could think about 4.56, but it might hurt mileage then. As far as where to get them done, just make sure somebody does them that really knows what they are doing, even if you have to drive an hour or two away, its worth it. There is a lot of stuff that can go wrong if they are not set up properly. Also, I would get a locker or limited slip while you're at it since you only have 2wd. Hope this helps a little.
Old 09-10-2001, 03:09 PM
theleetbeagle
Nice name, there, Nick.
Well, I have the 300 I6 so I am definetly thinking 4.56.
Swapping gears is more than just disassembling, putting in new, and reassembling, eh? Is there a lot of stuff that can go wrong? I mean I am a pretty competent mechanic, I've just never done gears before.
Lemme know!
-Nick.
theleetbeagle
Yeah, I was thinking ARB Air Locker, pricey, but worth it, especially since I already have an air compressor on board.
-Nick.
Old 09-11-2001, 02:10 PM
nick1's Avatar
nick1
nick1 is offline
Well, they say if you have to ask about how to swap gears, to have it done professionaly. It's expensive but if everything isn't exact, at the least they will be noisy and wear out really fast. With the 300 and overdrive, I would go with 4.56. Then if you want in the future, you could get away with bigger tires than 35's. With 4.56 and 35's you could even beat most people off the line. But to answer your question, there is a lot more to it then just disassembling and putting in new ring and pinion. As far as the ARB, that would be the ultimate set-up. Go with that if you can afford it (they aren't cheap). I have a Detroit locker in my 9" rear, it kicks ##### off -road and I don't even notice it on road. Definately worth every penny since they're proven to be indestructible.
Old 09-11-2001, 02:45 PM
85351ho's Avatar
85351ho
85351ho is offline
i agree, i actually drove an hour yesterday tto get mine done, i live here around atlanta, and i had a hard time even finding anyone, but i found a good one and talked to some people who have had his work done, cost me 1100 for new 410 gears for front 44, rear dana 60, all new seals and bearing too, that also includes labor, will be done tomorrow, i cant wait
1985 F-150/351Ho/c6/4wd~96,000 miles
1979 F-150extcab4x4/460/c6/6inchlift w/60rear44frnt 4.10 gears, 250 springs
37 boggers
Old 09-11-2001, 03:16 PM
theleetbeagle
Four Wheel Parts in Parma (Cleveland) Ohio want $2500 for the following:
6" Pro Comp Lift
American Eagle wheels
BF Goodies 35x12.5x15
Brake Lines
4.56 rear end
alignment
...all installed
You guys think that is a good price, eh?
Thanks!
-Nick.
Old 09-11-2001, 07:38 PM
gamehunter's Avatar
gamehunter
gamehunter is offline
sounds like a smokin deal to me. I don't think you would be saving much money by installing it yourself. I have heard people paying that much for just the lift.
'90 1/2 ton 4x4 XLT Lariat
RC LB w/5.0 EFI M50D 3.73gear
true duals w/glasspacks
