You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Okay, any of you Ford techs (yes, I'm hoping you see this Chris (redneckcowboy)). Have a check engine light on the Super Duty. Pulled code P0460- Fuel Level Sensore A circuit. Anyone with a clue?? I posted this in the SD thread too.
pat,
the fuel sender went south on you bud. i used to get those codes alot at the tranny shop. it will trigger a check engine lite but it won't throw the computor into limp home mode.
ford ranger
__________________
jack, slackmaster #6
1996 ford ranger xlt extended cab,2wd,4.0L v6,5spd,3.08 gears, tornado intake spacer, msd ignition,sun super tach2, k&n air filter, nascar oil filter.
pat,
ford ranger
Your pretty much saying that it would be in an pending status.
__________________
Chris
2004 F350 XLT 4x4 6.0L SC/LB 4x4
1998 Explorer Sport 4x4 4.0L
I am just a number and no I don't care about Trophy's
yep,
you can tell when its in limp home mode the lite will be on and the tranny will start off in a higher gear and won't shift. even if its not tranny related. but that isn't the case this time. pat if its still under warranty take it back to the dealer and get it taken care of! the race is on! at the dega! its on abc guys! just opened a beer. and watchin'.
later
ford ranger
__________________
yep,
later
ford ranger
thank god its a diesel, comes with an 100,000 mile warrenty
__________________
Chris
chris,
that 100,000 mile warranty only covers the engine, not the hole truck! now
depending on the type of warranty you have! now if its an 06' or older yes the power stroke is still covered. under 100,000 miles. unless you get the extended warranty, then your covered.
ford ranger
__________________
chris,
i know! i worked for a company that had a fleet of fords and the dealer
made me a rep. for warranty and recall and stuff like that. i worked in a fleet shop and sometimes ford will do that!
ford ranger
__________________
