Tranny problem... HELP! - Ford Truck Enthusiasts Forums
Old 10-01-2008, 06:18 PM
f-150 on 22's f-150 on 22's is offline
f-150 on 22's is starting off with a positive reputation.
I have a problem with my 2006 F150 4X4. I have had an intermitant problem (about a dozen times now) where after driving and I come to a complete or partial stop - during acceleration, I get a very loud noise - almost a grinding or draging sound from the transmission - sounds like maybe even a slipping sound. It's so loud that I have to pull off to the side of the road and then it stops - sometimes a loud clunk sound occurs. If I coast and put it in neutral it goes away.. any ideas??
Old 10-01-2008, 08:03 PM
Ok, so I went and got a new filter and gasket, and after I dropped the pan, METAL everywhere in my pan, the magnet is full of flakes, little chunks all over the pan.. Now I gotta get it towed to a good tranny place in Tallahassee... Anyone know a place?
Old 10-01-2008, 08:12 PM
xjcamaro89's Avatar
xjcamaro89 xjcamaro89 is offline
xjcamaro89 is gaining momentum as a positive member of FTE.
Is it still under warranty?
Old 10-01-2008, 08:14 PM
No, I think I'm going to cry
Old 10-01-2008, 08:52 PM
So, if I am correct, the torque converter is not removable and replaceable?
Old 10-01-2008, 09:45 PM
Timbo522 Timbo522 is offline
Timbo522 is starting off with a positive reputation.
I am having the same problem with my 05 4x4. Ford dealer had no idea what it was without tearing into it. You think it is the torque converter then?? Thanks.
Old 10-01-2008, 10:18 PM
Edge programmer picked up 2 codes... Anyone got any ideas? PO962 AND PO748
Old 10-01-2008, 10:36 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
From Diagnostic Trouble Codes (DTC)
Definition of Diagnostic Trouble Code P0962
This Definition of P0962 is Applied to All Manufacturers Powertrain: Pressure Control Solenoid “A” Control Circuit Low
Definition of Diagnostic Trouble Code P0748
This Definition of P0748 is Applied to All Manufacturers Powertrain: Pressure Control Solenoid “A” Electrical
Old 10-01-2008, 10:46 PM
ggwash21's Avatar
ggwash21 ggwash21 is offline
ggwash21 is starting off with a positive reputation.
I had the same issue, i just got my truck back from the dealer and $4375 is what the total bill would have been if i didnt have a warranty.. I had ton of shavings in the pan. I had worn out clutch packings and a few other things. My truck would SLAM going into 2nd and 3rd gear every so often, and down shift hard as if i was down shifting it manually.
Sorry it is happening to you... its not fun thats for sure..
Old 10-03-2008, 01:27 PM
So, after taking it to a shop up here and having them fix the truck......the whole planetary gear set was shot..... $1,800 later.
Old 10-03-2008, 02:23 PM
ggwash21's Avatar
Now get FORD ESP on that bad ride./...
Straight 6 sound loud! Kregj 1987 - 1996 F150 & Larger F-Series Trucks 4 09-04-2014 12:39 AM
2008 F150 Transmission Problem. Anyone with a like problem? brownsklan 2004 - 2008 F150 0 07-26-2012 02:21 PM
down shifting at highway speeds, gets very loud 99FORD EXPY. 2004 - 2008 F150 5 08-04-2011 04:31 PM
2001 f150 4.2 diesel sound F4L956 3.8 & 4.2L V6 6 06-06-2007 06:33 PM
Loud whistle coming from rear end walkerrim 1999 to 2016 Super Duty 3 08-24-2004 08:32 PM
Tags
2004, code, codes, control, diagnostic, dtc, f150, ford, p0748, p0962, po748, po962, shift, solenoid, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
