arg, right front axel squealing and vibrating
Just went to wash the engine over lunch, got half way to car wash and the front start making a terrible squeal. I could also feel a vibration in the floor boards. Breaks feel good so I assume its the axle. Never taken one apart and as this is my only truck at the moment I need it. How hard is it to lube the front end and what do I need to get just in case the bearing's are bad. A list of parts and where I can get them would be great.
With the amount of noise and vibration you are describing, it sounds like a wheel bearing failure.
The car wash really had nothing to do with it, perhaps the water finally pushed it over the edge, but it would have failed next day anyhow.
Unfortunately you have to buy the whole hub assembly for around $300.00+ to replace the front wheel bearings on the 4x4 Superduty.
so, did not get a hub assembly, wanted to do some more investigation before spending $399. Got home and jacked up the front. the wheel/break assembly will turn left / right , up and down without moving the steering wheel. Its like hub is lose. The wheel was bolted down to the studs just fine, the break disk moved with the tire. I will be posting some video i took when your tube is up. This could explain the tick,tick,tick,tick i hear when going 25-30 and turning left, but it only happens when i turn left, not right.
yes you have to replace the whole hub assembly, since they are not serviceable. when I did mine a few months ago, I got them straight from Ford as I know a guy in the parts department. I have a late 99 so there are a few different kinds for that year depending on build date so I didnt want to risk going with a cheaper one and it not being the right kind. they cost alil more from Ford, but mine lasted over 120k and I dont know if cheaper ones would do the same.
