No Low Range 2003 F250
Need more information. Do you have a manual system or ESOF, what kind of hubs are you using (less important, but could be useful), does it not engage into low or does the vehicle not move when in low?
My truck is a pain to get into and out of 4lo most of the time. It usually takes a big of rocking the truck back and forth and random shifts to neutral before I can get lo to engage.
It is EOS. with stock hubs. It moves OK, It just stays in high range.
I don't really need it a lot, but when backing my fifth wheel up a grade at home to park it. I thought I would try low range. It wasn't there. Had the brake on and in neutral when selected, but shift didn't happen. Thanks for the reply. Hammer
I know this may sound silly (and not trying to make anybody seem stupid) but these trucks have to be completely stopped, transmission in neutral and your foot has be on the brake for it to shift into and out of 4 wheel drive low. I work at a Ford dealership and I get calls about this all the time.
+1
(except the dealer part)
Nope. Neither the manual nor the ESOF. I've had it grind like a mother once when my hubs were getting weird when they were still auto hubs. I forgot what I did, but somehow the output shaft of the transmission was still spinning when the ESOF system tried to get into 4LOW. Ouch...
I hooked to my fifth wheel today, and then decided to try 4WL to backup up the drive.
Switched to 4WL and it didn't go in, switched back out and rolled a little and switched back in and it went right in. Really was nice for backing up the hill. Hit the level of the hill switched it out. It rolled about 5 ft and shifted out. Working about like I believe it should. Hammmer
351Cleveland C4
02-18-2014 06:27 PM
TrevorP
09-16-2007 12:57 PM
