Custom seat riser f1 - Ford Truck Enthusiasts Forums
Old 09-30-2008, 10:29 PM
sickfish sickfish is offline
sickfish is starting off with a positive reputation.
hello all,
I am in the process of a 51 f1 resto an i am looking for any custom seat riser ideas. the more trick the better! thanks, sf
Old 10-01-2008, 01:26 AM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Hi!
Mine is simple, functional and looks great - I have a few OLD photo's from before the interior was complete with only the temporary seat cover on - couple of years ago (and how much progress have we made since???).
All it is, is welded 2" angle iron that forms a box under the seat and down to two pieces of flat iron on the bottom. My seat rails bolt to the top surface. The flat iron bolts to the floor.
So, now I sit high enough and my legs aren't squished, and my arm sits just right on the window opening whan it's down.
I've made some masonite panels for the front and sides (2 on the front) I hold on with velcrow that I'll eventually cover with fabric or carpet, and I keep my tool bag, jack, etc. for the truck under there.
Simple but it works.
J!
PS I got the longest seat belts available and bolted them to the floor as well.
Old 10-01-2008, 09:37 AM
Scott123 Scott123 is offline
Scott123 is starting off with a positive reputation.
Mine is welded up from 1 inch square tubing. I cut and laid the tubing out to match the stock bolt holes in the cab floor and tacked up, then turned the seats (out of a Mazda truck) upside down, cut tubing and bolted to their stock holes, tacked, then just sat on top of the frame bolted to the floor and cut tubing to set the height I liked and welded it all up. Has worked very well.
Old 10-01-2008, 05:57 PM
Kusto's Avatar
Kusto Kusto is offline
Kusto is gaining momentum as a positive member of FTE.
I like Scott's riser, but I think I would gusset the corners for additional support, purely for safety reasons in the event of a crash.
Old 10-01-2008, 08:40 PM
dongc1's Avatar
dongc1 dongc1 is offline
dongc1 is starting off with a positive reputation.
I built a riser similar to Scott. I mounted my Ranger seat on it.
It works real well. Solid as a rock.
Old 10-02-2008, 12:25 AM
thanks everyone
thanks...
sooo,,, i have a confession to make... i actually have already made one, just wanted to compare to a few of the experts. Ive been looking for something to compare to see if what i have made has ever been done. I took old metal tubing from a chain link fence I removed and welded up a tubular frame. Next I took oak and finished the long sides and top. In the ends I made an oak face frame and then solid oak drawers on ball bearing slides. Its not totally done yet, but so far ive been working on it for around a month here n there... i would have to say if i did it again, even though i like the tube look, it was really hard to line it all up! thanks again for the replys n pics!
Old 10-04-2008, 03:07 PM
Kusto's Avatar
Post some photos of yours when you can.
1986 F350 351w heat riser gasket? Feenba 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 08-13-2012 09:11 AM
Seat riser attachment question tjdad62 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 03-18-2011 04:55 PM
Heat Riser - 226 Engine ct50f1 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-31-2010 10:16 PM
heat riser tube my79f Ford Inline Six, 200, 250, 4.9L / 300 9 04-09-2004 09:11 PM
Rear seat riser eddy13 1987 - 1996 F150 & Larger F-Series Trucks 9 01-09-2003 01:09 PM
Tags
build, bull, custom, f1, f250, floor, ford, frame, interior, metal, pickup, ranchero, riser, risers, seat, truck, trucks, welding, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
